Re: DIY Alignment Ideas? [Re: 80fbody] #1898905
08/25/15 08:44 AM
08/25/15 08:44 AM
Mass.
8
80fbody Offline OP
80fbody  Offline OP
Mass.
That tool Exit1965 posted seems like it may be the ticket. Price is right and it reads in 1/8 degree increments.
Re: DIY Alignment Ideas? [Re: 80fbody] #1900074
08/26/15 10:33 PM
08/26/15 10:33 PM
Lake Orion, MI
goldduster318 Offline
Lake Orion, MI
I used the speedway motors one on my car, a tape, to do the toe and some admittedly single use ceramic tiles for turn plates. So far so good. I ordered some $150 turn plates which should help make that easier in future uses. My old wheels worked well with the center caps removed with that gauge. Any set of stock wheels would work fine. Drives really nice.
'70 Duster 470hp 340/T56 Magnum/8 3/4 3.23 Sure-Grip
Re: DIY Alignment Ideas? [Re: 80fbody] #1900203
08/27/15 02:42 AM
08/27/15 02:42 AM
Cut and Shoot, TX
kentj340 Offline
kentj340  Offline
Cut and Shoot, TX
From the videos mentioned above, sprinkling a little salt between cheap linoleum tiles works plenty good for turn plates.
