Installing vinyl stripe questions #1896433
08/21/15 11:25 AM
08/21/15 11:25 AM
Virginia
HemiStan Offline OP
HemiStan  Offline OP
Virginia
I am going to install the stripe on my Super Bee this afternoon. I was reading the instructions and it states to leave the paper on the stripe for approximately 3 hours after installation before removing it to allow for proper adhesion.
I have installed a few stripes and I do not ever remember having to leave the paper on for three hours before removing it.
Does that sound right?
Thanks!
Stan
Re: Installing vinyl stripe questions [Re: HemiStan] #1896445
08/21/15 11:55 AM
08/21/15 11:55 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Seems the manufacture would best know how to apply there own product.
Re: Installing vinyl stripe questions [Re: HemiStan] #1897547
08/23/15 09:47 AM
08/23/15 09:47 AM
Port Saint Lucie, FL
ChallengerGary Offline
That is basically to allow any moisture that may still be in there to evaporate and to prevent an amateur/novice from doing something bad. I do vinyl graphics for a living and never leave the paper on because I know "the feel" of the material and don't worry about ruining the graphics by lifting/stretching the material away from the car while removing the transfer tape. I've had plenty of do-it-yourself people come to me and watch me do it and say, "man, you make it look so easy, I already ruined one set of graphics trying to do it myself."
Re: Installing vinyl stripe questions [Re: HemiStan] #1897587
08/23/15 11:35 AM
08/23/15 11:35 AM
Harrisburg, Pa.
screamindriver Online content
screamindriver  Online Content
Harrisburg, Pa.
Best advice for a first time I can give is : Don't pull the paper off straight up perpendicular to the car's surface..Angle it back almost against itself while peeling the paper it has less of a chance to lift the decal....
Re: Installing vinyl stripe questions [Re: screamindriver] #1897646
08/23/15 01:15 PM
08/23/15 01:15 PM
KY USA
mopargem Offline
mopargem  Offline
KY USA
I've done a lot of stripes and this is good advice to remove at a sharp angle. Also never wait three hours
68 Polara 500...LL1 Y7 M6X
69 Hemi road runner...X9 X9 M6X
69 A12 road runner....R4 R4 M6X
69 ModTop FLORAL Super Bee...F6 M6W
70 AAR 'cuda...EW1 EW1 H4X9
71 Duster 340...FJ6 V24 L6X9
71 road runner FC7 V1X M6X9
72 Rallye Charger B5 V1W
74 'cuda 360...KB5 V1X A6X9
08 SRT Challenger #234
Re: Installing vinyl stripe questions [Re: ChallengerGary] #1897652
08/23/15 01:23 PM
08/23/15 01:23 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I've done a bunch of large decal work at work on work trucks and usually leave the transfer tape on anywhere from an hour to over night before peeling it off.
Then I watched my painter friend apply some stripe decals and he sprayed the transfer tape with Rapid Tac application fluid to release it right away.
It seemed to work real well and I was going to use it on the stripes you sent me? Sound OK?
