alternator magnet test #1897146
08/22/15 03:43 PM
08/22/15 03:43 PM
ont,canada
mopartuner Offline OP
ont,canada
If a wrench doesn't get pulled into the back of the alternator it means its no good......why?is there any other reason this isn't magnetized?
410 pump gas solis flat tappet cam 10.95 so far
Re: alternator magnet test [Re: mopartuner] #1897165
08/22/15 04:27 PM
08/22/15 04:27 PM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Don't think that's correct. Alternator generates alternating current then rectifies through diodes.
Re: alternator magnet test [Re: Leon441] #1897169
08/22/15 04:40 PM
08/22/15 04:40 PM
langley b.c. canada
don miller Offline
don miller  Offline
langley b.c. canada
The back of the alternator (stator shaft) becomes magnetic when the fields are energized-in other words when the alternator is charging
Re: alternator magnet test [Re: mopartuner] #1897173
08/22/15 04:47 PM
08/22/15 04:47 PM
Andrews,In. U.S.of A.
67_Satellite Offline
No juice from the regulator = no magetism = no charge.
Re: alternator magnet test [Re: 67_Satellite] #1897259
08/22/15 07:28 PM
08/22/15 07:28 PM
southern Maryland
K
keefe Offline
keefe  Offline
K
southern Maryland
If I remember correctly.. if the alternator is good it will cause a magnetic field regardless of the voltage regulators condition. That's how we use to trouble shoot a bad alt. or reg.
1971 duster twister 440, 3380#,509 M/P hyd,906's,full Exhaust,11.06@117.46 1/4,6.95@ 97.03 1/8,1.497 60ft.....
Re: alternator magnet test [Re: keefe] #1897556
08/23/15 10:21 AM
08/23/15 10:21 AM
Lynchburg, VA
Leon441 Offline
Leon441  Offline
Lynchburg, VA
Always used a meter.
Didn't realize the stator shaft poles when charging.
Re: alternator magnet test [Re: mopartuner] #1897644
08/23/15 01:15 PM
08/23/15 01:15 PM
Charlotte, North Carolina
sgcuda Offline
sgcuda  Offline
If it pulls, it means everything is working. If it doesn't, there is a problem, but it doesn't tell you where. Could be alternator, regulator, field wiring or B+. Just a quick Good/No good check.
[image][/image]
Re: alternator magnet test [Re: sgcuda] #1897657
08/23/15 01:26 PM
08/23/15 01:26 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I never heard of the test of if its magnetic its good.. you
have to energize the field to create the field... I always
use to try a full field test first at the regulator.. if it
works then change the reg.... a vom can test a lot of things
wave
Re: alternator magnet test [Re: mopartuner] #1897662
08/23/15 01:30 PM
08/23/15 01:30 PM
sgcuda Offline
sgcuda  Offline
Try putting a screwdriver blade to the back of any alternator. It will always pull down on a working charging system. This is old school I learned from my first boss when I was in the gas stations and regular gas was still available (am I showing my age a little?).
[image][/image]
Re: alternator magnet test [Re: mopartuner] #1897700
08/23/15 02:33 PM
08/23/15 02:33 PM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
Keep in mind...
That an alternator may still have some output but be below spec...
Put a voltmeter on it, should have 13.5-14.5V output. If U dont have a voltmeter, check with Harbor Freight they have a give-away one or sells for $5..
Just my $0.02... wink
