Page 2 of 4 1 2 3 4
Re: Quick Trans ? [Re: DemonDust] #1896226
08/20/15 10:15 PM
08/20/15 10:15 PM
MR_P_BODY Offline OP
Originally Posted By R5P7Duster
Sounds like you have a lock up pump and non lock up convertor. Or vice versa. It will almost seem like you have a trans brake and you have to rev it up and then it will hit.
I made this mistake before, scratched my head for weeks.
The pump I put in it worked fine in the first trans... that
trans we forgot a torrington bearing in the OD and after about
400 miles it ate up the OD drum... so that pump worked.. I
got it from Cope.. and I picked up another pump from him for
my spare trans
wave
Re: Quick Trans ? [Re: MR_P_BODY] #1896375
08/21/15 03:18 AM
08/21/15 03:18 AM
Affton MO
Q
qwkmopardan Offline
qwkmopardan  Offline
Q
Affton MO
Don't give up. Just put a 727 in there and be done with it. Car will only get maybe 2mpg better with the 518. Set the cruze control on 3700 and wear ear plugs. Overdrives are overrated.
Re: Quick Trans ? [Re: MR_P_BODY] #1896394
08/21/15 08:44 AM
08/21/15 08:44 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
If I had an overdrive I would still cruise at the same RPM as my car is really happy there(at least with the old motor) so an overdrive would just be there faster lol.
68 Barracuda Formula S 340
Re: Quick Trans ? [Re: MR_P_BODY] #1896415
08/21/15 10:35 AM
08/21/15 10:35 AM
Amarillo, Texas
BBR Offline
BBR  Offline
Amarillo, Texas
727 727 727 727 F that OD!
Drag Week 2011 - 77th place - DD
Drag Week 2012 - 2nd place SRBB N/A
Drag Week 2014 - Kapooya
RMRW 2018
RMRW 2020
Re: Quick Trans ? [Re: MR_P_BODY] #1896416
08/21/15 10:35 AM
08/21/15 10:35 AM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Mike this is the used trans, or the one just rebuilt?
Re: Quick Trans ? [Re: dizuster] #1896418
08/21/15 10:47 AM
08/21/15 10:47 AM
Used... bought it at the bone yard... pulled the
pan and the oil was good and almost nothing in
the pan (trash).... I went thru the one that was
in it... I feel sure its good but I have lost my
confidence... I'm gonna run it up to a trans shop
in Almont thats suppose to be good on mopars and have
him take it apart.. if he can get it done in a couple
of days I'll pull the engine/trans
wave
Re: Quick Trans ? [Re: MR_P_BODY] #1896427
08/21/15 11:07 AM
08/21/15 11:07 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Lmao
Re: Quick Trans ? [Re: FastmOp] #1896429
08/21/15 11:11 AM
08/21/15 11:11 AM
Originally Posted By FastmOp
Lmao
I sure dont find it funny
wave
Re: Quick Trans ? [Re: MR_P_BODY] #1896441
08/21/15 11:36 AM
08/21/15 11:36 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
come on... you have to find a little humor in the fact that you've taken a lot of time, carefully plotted and executed your plan..... just to be at crunch time and now wondering if Billy's brothers are going to make it and you aren't! YOU CAAANNN DO IT! kind of reminds me of my situation. 26 passes on a new combo, have had the trans out twice and it's now currently at Pro Trans. I threw in the towel.... At least when it gets done it will be right and I'll be able to have some fun..... (laugh2....we always think that for some reason)
Re: Quick Trans ? [Re: John_Kunkel] #1896478
08/21/15 01:04 PM
08/21/15 01:04 PM
NC
440Jim Offline
440Jim  Offline
NC
Originally Posted By John_Kunkel
Balky Reverse and drives forward in Neutral is a rear clutch that's not releasing...usually due to a failed Belleville. Has to come out.
That is what came to my mind also (rear clutch not competely disengaged).
Re: Quick Trans ? [Re: 440Jim] #1896482
08/21/15 01:11 PM
08/21/15 01:11 PM
I took my spare trans into the shop..this is the one
I rebuilt myself... it should be fine.... but to be
safe I took it in... I'll let them check it out... and
he can have it done in 3 days... he said he'd pull it
apart this evening.... so the engine and trans are coming
out again.. today
wave
Re: Quick Trans ? [Re: Kindafast] #1896530
08/21/15 02:39 PM
08/21/15 02:39 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Originally Posted By Kindafast
My trans has always tried to creep in neutral and it works fine. Check your band adjustments front , the easy one and then try the rear " the one inside.
Creeping in Neutral due to a tight rear clutch pack isn't all that unusual but the OP also has a bind-up in Reverse which isn't normal.
Band adjustment has nothing to do with transmitting power, bands are brakes used to stop components from moving not to connect components...only clutches do that.
Re: Quick Trans ? [Re: MR_P_BODY] #1896553
08/21/15 03:09 PM
08/21/15 03:09 PM
nielsville, minn.
Q
quickd100 Online content
quickd100  Online Content
Q
nielsville, minn.
If I lived close by I'd be there to give you a hand Mike. Dave
Re: Quick Trans ? [Re: John_Kunkel] #1896556
08/21/15 03:19 PM
08/21/15 03:19 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
This is why I brought up mismatched Converter and front pump. I've had it happen and this is exactly what it did to me. Not sure why it does it. But it did.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: Quick Trans ? [Re: DemonDust] #1896622
08/21/15 04:32 PM
08/21/15 04:32 PM
This pump and this conv were working fine for over
400 miles till the OD drum burn up due to no torrington
in the one thats in the shop now
wave
Re: Quick Trans ? [Re: quickd100] #1896630
08/21/15 04:43 PM
08/21/15 04:43 PM
Thanks... I'm just about ready to pull the engine/trans
but I have to turn the car around... 2 of my buddies will
be here in the morning to help turn it around... I'll pull
tomorrow... then wait for the trans... if he tells me that
everything looks good in the one I did.. then I'll do this
one also as a spare.. I want him to verify the whole thing
wave
Re: Quick Trans ? [Re: MR_P_BODY] #1896639
08/21/15 05:02 PM
08/21/15 05:02 PM
Also.. found that its different today from yesterday..
today it moves about 10" in reverse and locks up... put
it in park then back into reverse it moves 10".. I did
this about 20 times trying to turn the car around... then
said F-it and pulled forward onto the hoist to start tearing
things apart ... turn it around tomorrow and pull it out
wave
Re: Quick Trans ? [Re: MR_P_BODY] #1896685
08/21/15 06:27 PM
08/21/15 06:27 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
Mike, I had this happen on a 47RE in a diesel truck one time. It turned out that it had broken the middle ring on the input shaft.
As I remember this middle ring seperates the rear clutch and converter lube circuit. When the ring is broken, the converter lube will actually apply the rear clutch. Normally this isn't a problem because the rear clutch is "on" in all forward gears.
But it can cause the vehicle to move forward in Neutral, and bind in Reverse.
Isn't this the ring that you damaged that I had Tiffany drop off to you? Maybe it is damaged again (or a mismatch of parts not allowing them to go together properly?)
Re: Quick Trans ? [Re: dizuster] #1896723
08/21/15 07:25 PM
08/21/15 07:25 PM
The trans thats in the car is from the bone yard..
I changed the pump and input shaft and put a drain
plug/temp gauge on it... thats all I did so maybe
this thing was broke when I bought it... it just
looked decent inside... if I changed the pump and the
input shaft is in it... could I have broken that ring
but the pump did slide in nice.. I used pins to align it..
but this sounds lie how its acting
wave
Re: Quick Trans ? [Re: MR_P_BODY] #1897756
08/23/15 04:58 PM
08/23/15 04:58 PM
Texas
dannysbee Offline
dannysbee  Offline
Texas
Hope you get it worked out Mr. P. You
U definatly deserve a break.
Getting old just means you were smarter than some and luckier than others.
Page 2 of 4 1 2 3 4
