Re: Racing Powerglide Tranny Fluid
[Re: Biginchmopar]
#1896111
08/20/15 07:33 PM
08/20/15 07:33 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Oreiily or Napa or Walmart Type F. If you want trick of the week bada$$ stuf contact LAT
[Re: Biginchmopar]
#1896218
08/20/15 10:07 PM
08/20/15 10:07 PM
Posts: 11,551 Fulton County, PA
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Not what you likely consider high horsepower, but we had the best luck with Carquest, NAPA, Valvoline Type FA. The Carquest stuff may not be the same since Advance bought them out and cheaped out on everything. Amsoil does a synthetic Type F that I've heard good things about.
[Re: Biginchmopar]
#1896232
08/20/15 10:27 PM
08/20/15 10:27 PM
Posts: 43,157 Bend,OR USA
Cab_Burge
Mikes Monster Glide Tranny special mix in Lancaster Medium HP, 700 or so
[Re: Cab_Burge]
#1896265
08/20/15 10:58 PM
08/20/15 10:58 PM
Posts: 20,173 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Walmart dextron 3 for me.
[Re: Biginchmopar]
#1896311
08/21/15 12:30 AM
08/21/15 12:30 AM
Posts: 4,675 On the parachute mount
n20mstr
Per rossler I tried type F and tractor fluid. The tractor fluid seemed to slow the car down, I guess I didn't have enough HP ..... LOL As far as what brand.....whatever is cheapest as long as it is type F
....BAD A$$ STREET CAR.....
[Re: Biginchmopar]
#1896396
08/21/15 09:13 AM
08/21/15 09:13 AM
crabman173
crabman173
I use type f Walmart in my dragster--works like a dream and I can afford to change it more often--I like the Napa type F but prices have just gone up and up on it--Walmart for me! Trick fluid never offered any advantage that I could point to except on paper. If you use a trans brake hard with big HP then I am guessing a synthetic will give you more protection against the heat breakdown--or...just us Walmart and change it out when needed.
[Re: Gary Robbins]
#1896480
08/21/15 01:10 PM
08/21/15 01:10 PM
Posts: 20,173 PA.
pittsburghracer
"Little"John
"Little"John
PA.
Wow I thought the type f thing was long gone,Lol.
MOPAR ATF+4 here...If it can go 100K miles in my diesel truck it'll work in my HOTROD !!
I kind of chuckle when I read about Type F tranny fluid. That is sooooo old school and my trans builder got me out of that long ago. Probably the only reason they still make it is for the purple shaft crowd. LOL
[Re: Biginchmopar]
#1896522
08/21/15 02:29 PM
08/21/15 02:29 PM
Al_Alguire
Las Vegas
We use LAT in the heads up car, also have tried the ATI synthetic funny it is also called Type F, Super F to be exact and John Deere Low Vis Hygard as well. Anyway have not really noticed a big difference with any other than there is a stall difference with the Hygard. In the end the we have tried a lot and not noticed any difference in performance. I settle on the low cost type F stuff for the .90 car and IMO next to a turbo car they seem to be the hardest on transmission fluid.
[Re: Biginchmopar]
#1896524
08/21/15 02:30 PM
08/21/15 02:30 PM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
Don't know anything about there trans fluid but I love the Torco 85w140 RGO I put in my 8.75!
[Re: Gary Robbins]
#1896526
08/21/15 02:31 PM
08/21/15 02:31 PM
Posts: 25,785 Rio Linda, CA
John_Kunkel
Rio Linda, CA
MOPAR ATF+4 here...If it can go 100K miles in my diesel truck it'll work in my HOTROD !! A fluid purposely formulated to make clutches/bands slip...excellent choice for a race car.
[Re: John_Kunkel]
#1896547
08/21/15 02:58 PM
08/21/15 02:58 PM
dartman366
Mt. Vernon, Ohio
MOPAR ATF+4 here...If it can go 100K miles in my diesel truck it'll work in my HOTROD !! A fluid purposely formulated to make clutches/bands slip...excellent choice for a race car. exactly why I won't use it, at least in the race car, not impressed with it in my 93 dodge diesel dually either.
[Re: Biginchmopar]
#1896597
08/21/15 03:57 PM
08/21/15 03:57 PM
CMcAllister
Mr. Helpful
Mr. Helpful
Fulton County, PA
Never tried Dex/Mercon, but I've tried the "slippery" synthetic ATF. High gear clutches came out black streaked and steels were blued. Went back to Type FA and the problem went away. Typically with the Type FA we just wash the clutches and steels, measure them and put them back in.
[Re: Biginchmopar]
#1896614
08/21/15 04:14 PM
08/21/15 04:14 PM
Posts: 2,422 Pittsburgh PA
Eric
Pittsburgh PA
I've used Mobil1 in the past for trans temp..... but I went back to Type F.
5.53 @ 125 1/8th on the launch control..more left in her!
[Re: dartman366]
#1896667
08/21/15 05:50 PM
08/21/15 05:50 PM
Posts: 803 Idabel,Oklahoma
Gary Robbins
Idabel,Oklahoma
MOPAR ATF+4 here...If it can go 100K miles in my diesel truck it'll work in my HOTROD !! A fluid purposely formulated to make clutches/bands slip...excellent choice for a race car. exactly why I won't use it, at least in the race car, not impressed with it in my 93 dodge diesel dually either. Works good in my junk with absolutely no issues for years...Maybe I'm gettin by with it cuz I'm slow and only go low teens 60' and 4.70's to the 1/8th at 3250# on 275 drag radials !!
