Re: 383 Distributor in 440
[Re: ringo440]
#1893885
08/17/15 09:27 PM
08/17/15 09:27 PM
Posts: 25,618 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Nothing commercially available to do that swap. Only practical way to make it work is to change the shaft in the distributor to an RB shaft.
[Re: ringo440]
#1894225
08/18/15 10:03 AM
08/18/15 10:03 AM
Posts: 13,319 Marion, South Carolina [><]
an8sec70cuda
It's pretty easy to swap the shaft out. Why worry w/ welding it?
[Re: an8sec70cuda]
#1894233
08/18/15 10:21 AM
08/18/15 10:21 AM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
It's pretty easy to swap the shaft out. Why worry w/ welding it? He'd basically have to find a dual point RB distributor as the donor, may as well just put that in. Cut the shaft, use a coupler to adjust the length and run it, not a lot of stress there.
[Re: mopar muscle7271]
#1895213
08/19/15 10:47 AM
08/19/15 10:47 AM
Posts: 5,097 Western Md.
skicker
"The Champ"
"The Champ"
Western Md.
heres a adapter right here u can get. Shouldn't that read "Fits RB to B"? I don't see how it can work...
...FAFO...
[Re: skicker]
#1895255
08/19/15 11:48 AM
08/19/15 11:48 AM
Posts: 74,907 U.S.S.A.
JohnRR
U.S.S.A.
heres a adapter right here u can get. Shouldn't that read "Fits RB to B"? I don't see how it can work... Correct , the description is wrong . The only way do do it is to make an extension or find and RB shaft... good luck .
#1895445
08/19/15 04:43 PM
08/19/15 04:43 PM
JohnRR
U.S.S.A.
Wrong again , there is no adapter like the one pictured because a 383 dist. needs a LONGER SHAFT , those adapters space the dist. off the block because of the 440 shaft . The difference between the 2 you linked are because an MSD billet will not fit in one that is made to fit a stock dist.
[Re: JohnRR]
#1895466
08/19/15 05:28 PM
08/19/15 05:28 PM
skicker
"The Champ"
"The Champ"
Western Md.
This is off the wall but...318-440 shafts are very near the same length. Would there be a down side to using a 318 single point shaft? I know the rotation is opposite...is the profile the same going each direction?. With no picture of the distributor in question I can't picture exactly what the dual point reluctor looks like... Is the distributor like this one?
...FAFO...
[Re: skicker]
#1895502
08/19/15 06:28 PM
08/19/15 06:28 PM
Posts: 43,007 Bend,OR USA
Cab_Burge
Years ago I made the mistake of using a 383 B motor distributor in a 318 A motor, I could get it to start fine but it would retard the timing the higher I revved it RB and B distributors rotate counter clockwise, A motors are the opposite so if you used the 318 A motor shaft and advance mechanism it will probally do the same thing
[Re: skicker]
#1895619
08/19/15 09:47 PM
08/19/15 09:47 PM
Posts: 235 ga
ringo440
ga
Yes that is the type.
[Re: dogdays]
#1895631
08/19/15 10:00 PM
08/19/15 10:00 PM
Supercuda
About to go away
About to go away
up yours
Miracle! I agree with Supercuda. Let that be your mantra, grasshopper.
