Re: Which block for Stroker?
[Re: DusterKid]
#1895083
08/19/15 01:53 AM
08/19/15 01:53 AM
Posts: 43,284 Bend,OR USA
Cab_Burge
I'm debating on which block to use for a stroker. Is it better to use a 400 or a 440 block? I have a set of 440 Source Heads (unported version) and a Mopar .590 cam that I'd like to use. I do have a 440 intake, but it is an older Weiand 7512 (Rated for 3000-6500) and a Holley 850 DP. Pretty sure the carb will be to small and will have to get another one. I have both 400 and 440 blocks that would require the same amount of machine work. Engine will be strictly a race motor and wouldn't be turned more than 6500. Trying to get a 3200 lb car to go 10.20's. Your probally going to need a better set of heads and a better cam to acheive your goals How much compression and fuel are you planning on using?I'm in the middle of building a motor similar to your planned motor, 400 block bore to 4.375, 4.250 stroke with a set of unported Source heads, I've already told the customer we are probally going to need a better set of heads to reach his goal of 700 HP on Oregon 91 octane pump swill I've built several different versions of race and pump gas Mopar stroker wedge motors, to reach 700 HP with 511 C.I. or larger C.I. motor you need a set of M.W. size ports that will flow at least 340 CFM at .700 lift on the intake side It is all doable depending on how hard you want to work and how much money you want to spend
[Re: DusterKid]
#1895384
08/19/15 02:59 PM
08/19/15 02:59 PM
Posts: 31,068 Oregon
AndyF
Either block will work, 440 is a little easier to find intake manifolds for as well as headers. You might want to double check on both before you make a decision. A 440 block with a 4.25 crank will get the job done. Get the heads ported so they flow 300+ at .600 lift. The .590 cam might get the job done. You only need 600 hp to go 10.20 at 3200 lbs so that is fairly easy trick for a 505 engine. The 850 carb is fine for 600 hp. You need 1.4 cfm per hp so 600 hp is 840 cfm. The CNC porting from 440Source should work fine or send the heads to Porter Racing Heads and have him fix you up. The Weiand intake should work okay at 600 hp. Biggest decision is compression ratio. I'd probably shoot for something in the low 10's if you want to drive on pump gas. You can race on a mixture of unleaded premium and race gas or mix with Hot Rod 102 or something like that. If it is a race car only and you're willing to buy race fuel then increase the compression to 12:1 with a flat top piston and run race gas. There are a bunch of tech articles that cover similiar engine builds. Take a look at my 505 article with a big flat tappet and slightly ported Edelbrock heads. That engine made about 650 hp and it would be very similiar to what you're trying to build. http://www.moparmax.com/tech/2011/vi_8-flat-1.html
[Re: DusterKid]
#1895406
08/19/15 03:32 PM
08/19/15 03:32 PM
Posts: 277 MN
Willie68coronet
MN
Since you have both a 400 block and 440 block. I'd have them sonic checked and use the best one. I've had three checked and two were good one was marginal.
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
[Re: DusterKid]
#1895552
08/19/15 07:31 PM
08/19/15 07:31 PM
Posts: 10,016 Frostbitefalls MN (Rocky&Bullw...
gregsdart
A couple of 750 carbs on a tunnel ram help to the tune of 30 or more hp, if that interests you. I had good luck with an 80s vintage TR intake, then ported it and gained an additional tenth by porting it out to bigger runner size.
