Re: Any reason NOT to lock out my MSD
[Re: Bad340fish]
#1895773
08/20/15 08:54 AM
08/20/15 08:54 AM
Posts: 4,243 Charlotte, North Carolina
sgcuda
I sure am glad I can adjust this with a keyboard now. I don't know about that. My Hemi 6 setup is time consuming to pull up maps, reposition timing/rpm points, save data, transfer to MSD, and then test drive. As opposed to the turn of a 1/2" wrench on the fly. Plus, my HP DV6 laptop blue screens if I start the engine while hooked up, which slows the whole process down even more.
[image][/image]
[Re: sgcuda]
#1895858
08/20/15 12:06 PM
08/20/15 12:06 PM
Posts: 52,972 Romeo MI
MR_P_BODY
I sure am glad I can adjust this with a keyboard now. I don't know about that. My Hemi 6 setup is time consuming to pull up maps, reposition timing/rpm points, save data, transfer to MSD, and then test drive. As opposed to the turn of a 1/2" wrench on the fly. Plus, my HP DV6 laptop blue screens if I start the engine while hooked up, which slows the whole process down even more. I learned a lot about my Holley EFI yesterday.. it was a good day for both the car and myself for learning
[Re: sgcuda]
#1895933
08/20/15 02:39 PM
08/20/15 02:39 PM
Posts: 8,082 Tulsa OK
Bad340fish
Tulsa OK
I sure am glad I can adjust this with a keyboard now. I don't know about that. My Hemi 6 setup is time consuming to pull up maps, reposition timing/rpm points, save data, transfer to MSD, and then test drive. As opposed to the turn of a 1/2" wrench on the fly. Plus, my HP DV6 laptop blue screens if I start the engine while hooked up, which slows the whole process down even more. I am running a Megasquirt ECU but I am only using the ignition side of it right now. As soon as I press enter my changes happen, can do it with the car running or whatever.
68 Barracuda Formula S 340
