Intermitten failure to start. #1893716
08/17/15 06:08 PM
08/17/15 06:08 PM
Missouri, U.S.A.
JSSuperbee Offline OP
Missouri, U.S.A.
1969 383 Superbee with MOPAR electronic ignition (distributor &
orange module). Car always started & run perfect all these years.
Restored 6 years ago. Battery perfect and turns over great. When
it first acted up a friend jiggled the wires on the resistor. It
then started up. Put on a new resistor. It ran and started fine for a couple days. Then.....same thing again...no start. Checked
the connections on the resistor. A little loose but tight enough
it should have started. Maybe it's the orange ignition module.
Replaced it. Ran and started fine for a couple days and then again it wouldn't start. When I let off the key from the start
position it "pops" like it wants to start. I tightened up all the
connections going to the resistor but still have the intermittent
won't start problem. Could it be the ignition switch?
James Stinebaker
Re: Intermitten failure to start. [Re: JSSuperbee] #1893744
08/17/15 06:32 PM
08/17/15 06:32 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
More likely than the switch would be the wires at bulkhead connector. They get funky over the years.
Re: Intermitten failure to start. [Re: JSSuperbee] #1893775
08/17/15 07:10 PM
08/17/15 07:10 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Mine acted the same way with the little shudder when you release the key. I found the reluctor to pickup at .024 when it should be at .008 measured with a brass feeler gauge.
Re: Intermitten failure to start. [Re: ademon] #1893799
08/17/15 07:37 PM
08/17/15 07:37 PM
Missouri, U.S.A.
Missouri, U.S.A.
What made you suspect the reluctor and how do you correct the
problem? Do I buy a new distributor if the gap is too large?
James Stinebaker
Re: Intermitten failure to start. [Re: JSSuperbee] #1893832
08/17/15 08:27 PM
08/17/15 08:27 PM
md
mopars4ever Online content
mopars4ever  Online Content
md
take the cap off and check the gap with a brass feeler gauge, if not .008 then loosen the screw on the pickup and set it to the correct gap. btw, even on a new distributor you should still check the gap before installing
Re: Intermitten failure to start. [Re: JSSuperbee] #1893835
08/17/15 08:32 PM
08/17/15 08:32 PM
Catskill Mountains, NY
Joe12459 Offline
Joe12459  Offline
If it started after you jiggled the wire, it is possible the wire is broken inside the insulation. If you disconnect the wire from the resistor, and pull on the end, it should pull apart if it's broken inside. I've had that happen to me several times.
Re: Intermitten failure to start. [Re: JSSuperbee] #1893841
08/17/15 08:36 PM
08/17/15 08:36 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Pull the bulkhead connector and check for corrosion. Very common problem on old Mopars. When you move the wires to the resistor it moves the bulkhead wires and gets them to make contact for a while. I believe it is the light blue wire in particular that causes issues.
Re: Intermitten failure to start. [Re: JSSuperbee] #1894024
08/17/15 11:22 PM
08/17/15 11:22 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Went through all the wiring, installed a new ignition switch swapped out coil and ecu. Just found it on a hunch, I had the mopar distributor with the adjustable advance slots so i was in the distributor several times making fine adjustments. I do think the hold down screw for the pickup doesn't hold it tight so I used a star type lock washer under it before cranking it down after the gap was set!
Re: Intermitten failure to start. [Re: ademon] #1894132
08/18/15 02:01 AM
08/18/15 02:01 AM
Missouri, U.S.A.
Missouri, U.S.A.
I have the standard Electronic ignition conversion distributor. It has only 2100 miles on it. Same for the brand new wiring
harness & bulkhead. When initially installed, I just dropped it in and it fired up and has run like a million bucks up until
now. Does the distributor I have have the adjustable advance slots and the hold down screw for the pickup. Is this screw
loosened, then the adjustment to .008 made and then tightened?
Do you recommend I take it to the local Dodge dealer to be
checked out since I'm not sure of myself and don't have
access to a brass feeler gauge?
James Stinebaker
Re: Intermitten failure to start. [Re: JSSuperbee] #1894136
08/18/15 02:06 AM
08/18/15 02:06 AM
you would line up the magnet with a tooth then set that gap between the magnet/tooth with a .008" brass feeler gauge (your parts house will have a set of several brass ones one of which is .008". As said clean the bulkhead (metal bristle brush for the male half ones/spare male terminal for the female ones (NAPA 725147 99cents or one from your parts wiring pile}. check your terminals again. pull the yellow wire off of the starter relay to disable the starter & with a helper confirm the coil positive primary and blue/yellow ECU terminals are BOTH getting fire in ign1 ("run", key on) and in ign2 helper holding key to "start" (4) checks
Re: Intermitten failure to start. [Re: JSSuperbee] #1894149
08/18/15 02:43 AM
08/18/15 02:43 AM
So Cal
Sinitro Offline
Sinitro  Offline
So Cal
U can set the reluctor gap with a business card...
Just move the pickup in close to the reluctor but not touching, insert the business card to check for adequate clearance, rotate the distributor to make sure everything kleers..
Note that problems can arise when the gap is too wide, and the ECU box will not fire but very few issues when set on the close side..
Also the point of kleening the bulkhead connections is pertinent...
After 40 years the connections get krusty and oxidized.. Pull the connector apart, kleen with a small wire brush, slightly crimp down titer the female tab connector, coat with dia-lectric grease and reconnect...
Just my $0.02... wink
Re: Intermitten failure to start. [Re: Sinitro] #1894156
08/18/15 02:50 AM
08/18/15 02:50 AM
I just miked (2) business cards, one was 11&1/2 tho and the other was 15 and a half tho ! that is doable cuz the vac adv will open it way farther than that in operation. EDIT I did have that one spark same deal when letting off & it was either the ECU or the ballast I forget which. I was hesitant on posting/suggesting that since he has replaced both (& the prob can be elsewhere)
Re: Intermitten failure to start. [Re: JSSuperbee] #1894342
08/18/15 01:26 PM
08/18/15 01:26 PM
MD
p d'ro Offline
p d'ro  Offline
MD
Is it cranking and not starting, or not cranking at all??
Re: Intermitten failure to start. [Re: slantzilla] #1894369
08/18/15 01:59 PM
08/18/15 01:59 PM
Eugene, Oregon
minivan Offline
minivan  Offline
Eugene, Oregon
I would agree with this...
but, I was having the same problem plus charging problems on my 67.. NEW everything on car... Turned out to be the battery cable connection on the starter relay was loose.. Not floppy loose, more snug than tight kind of loose... Might check it..
Re: Intermitten failure to start. [Re: JSSuperbee] #1894486
08/18/15 03:48 PM
08/18/15 03:48 PM
Madrid, IA
hellrzr Offline
hellrzr  Offline
Madrid, IA
My car was turning over fine but I had no spark and the power cable was getting hot. After swapping everything around I finally changed the starter and that seems to have fixed the problem. Everything on my setup was also new with maybe a few hundred miles on the parts but they are like 10 years old since I don't put a lot of miles on the car. I also had the electrical cutting out and causing the engine to shut off and then would not restart due to no spark. I'm not sure if that was related to the starter or perhaps a lose connection I just happened to fix while swapping parts and testing. Either way see if your battery cable is getting hot it might just be the starter!
Re: Intermitten failure to start. [Re: p d'ro] #1894504
08/18/15 04:08 PM
08/18/15 04:08 PM
Missouri, U.S.A.
Missouri, U.S.A.
It cranks great......just that sometimes, not always it won't start.
James Stinebaker
Re: Intermitten failure to start. [Re: Sinitro] #1894530
08/18/15 04:42 PM
08/18/15 04:42 PM
Missouri, U.S.A.
Missouri, U.S.A.
I just now checked the gap with a business card as you suggested.
It seemed a little loose but not much. I set it and cleaned the
tip of the rotor. It might take as much as 2 weeks before I know
if the problem is solved as most of the time it has been starting but not always. As for the wiring and bulkhead.....they
are all brand new. I installed all new when I restored the car.
I only have 2100 miles on the restoration, so the bulkhead should
be good.
James Stinebaker
Re: Intermitten failure to start. [Re: JSSuperbee] #1894536
08/18/15 04:52 PM
08/18/15 04:52 PM
Western Md.
skicker Offline
"The Champ"
skicker  Offline
"The Champ"
Western Md.
Check to make sure the orange box has a good ground thru the paint... shruggy That one bit me once in the beginning as I didn't want to scratch off the new paint... twocents
...FAFO...
Re: Intermitten failure to start. [Re: JSSuperbee] #1895049
08/19/15 01:15 AM
08/19/15 01:15 AM
s. e. pa.
calrobb2000 Offline
calrobb2000  Offline
s. e. pa.
hi
check the wire plugs at base of stering colom,
clean the plugs with elictrical cleaner and make sure they plug together correctly .
Re: Intermitten failure to start. [Re: JSSuperbee] #1895100
08/19/15 02:24 AM
08/19/15 02:24 AM
Madrid, IA
hellrzr Offline
hellrzr  Offline
Madrid, IA
The times it cranks great but won't start do you know if it's getting any spark? Mine would do that. It cranked fine and would not start and I would check and have no spark but I would try again and it would have spark and then suddenly no spark again. It was very frustrating. It seems the starter going bad was pulling so much power from the battery that there wasn't enough power left to create a consitant spark to fire the coil.
When it does start does it die suddenly?
Like others have said, check that the ECU is grounded and check for loose contacts.
