Page 5 of 5 1 2 3 4 5
Re: Mark Williams Billet Caps for 8 3/4 [Re: B3422W5] #1892900
08/16/15 12:03 PM
08/16/15 12:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Originally Posted By B3422W5
Originally Posted By bubby440
Hmm? 3200# car, 9.79 @ 135.5 ... takes around 590-600rwhp to do that, 700hp seems legit to me.
My ex car weighs 3220 currently. A while back the motor made 705 ish horsepower on a dyno with Best machine.
That motor went 9.62@ 140 on super stock springs.
That almost 5 more mph than the above. Huge difference
When I had the car( little bit different combo) it went 135@ 3350. I figured it made about 640-650 REAL horsepower.
135@ 3250 ISNT 700 horsepower, it's a great elapsed time, but it isn't 700. More like probably 640-645.
Again, first pass off the trailer and definitely a 9.60 based on being lean and other small issues plus a lot of you guys race in really good air back east etc. It was around 800+ ft. corrected iirc and definitely better than the normal 2000-3000+ and higher we see here on the west side. We`ll soon see how it runs w/all of my mods and at 3050 lbs................ luck
Re: Mark Williams Billet Caps for 8 3/4 [Re: runnerrt] #1893026
08/16/15 04:47 PM
08/16/15 04:47 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Dyno numbers, speculation and all the other stuff doesn't mean squat. Numbers at the track is all that matters. At 3200lbs, it takes roughly 575 rwhp to run 135mph in average weather conditions. If you want to figure 20% driveline loss, that would put the HP number at roughly 690. Can't remember exactly how big his motor is, but that puts HP in at roughly 1.35 per cube or so. Easily attainable with decent parts.
Re: Mark Williams Billet Caps for 8 3/4 [Re: runnerrt] #1893040
08/16/15 05:09 PM
08/16/15 05:09 PM
North Central, Indiana
Roughbird72 Offline
Roughbird72  Offline
Is there any average/standard loss of HP through the drive train? I know the number will vary on the setup. i was told one time it was in the 15%-18% range. shruggy
72 Plymouth Roadrunner 11.08@123.25
Re: Mark Williams Billet Caps for 8 3/4 [Re: J_BODY] #1893050
08/16/15 05:33 PM
08/16/15 05:33 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Originally Posted By J_BODY
If you we're making any real power you'd have broke that rear gear by now! laugh2 (come on! thats funny no matter who ya are!)
laugh2
This is what goes through my mind every time this is discussed. hop
Re: Mark Williams Billet Caps for 8 3/4 [Re: dartman366] #1893099
08/16/15 06:54 PM
08/16/15 06:54 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Originally Posted By dartman366
Originally Posted By Monte_Smith
Aftermarket ring and pinions are ALL made from exactly the same stuff. Yet some rears shell teeth off like chiclets and some hardly ever break. What, you think 8.75 gears are made weaker than Danas, or that slight increase in ring gear size "fixes" the issue...........hell no. It's ALL about stuff moving that is not supposed to move. It's been pointed out several times, that 8.75s and Danas, as well as Fords have roughly the same diameter pinion shaft and there is little difference in ring gear diameters..............so, if you look at it from something resembling a rational thought process, that leaves only the CASE as the inherent problem. Most all cast rears have cast caps. Why don't the rest of them spit caps off?
only real difference is the heat treat of that same material, as for the 8.75 they are a good diff for their intended purpose, but I changed to a D-60 after grenadeing my 8.75 and never looked back.
Here...
Rear End Technical Information
Pro Gears and Street Gears
Pro gears are made from 9310 and then heat treated. Itis a softer alloy than the 8620 Street gears. The softer 9310 alloy allows the gear to absorb higher impact loads that are generated in drag racing without developing cracks. A harder 8620 street gear could shatter under the same loads. As a side effect the "Pro" gears are not the best choice for street use as they will wear faster. Also available in the "Pro" gears is a large pinion with a 35 spline shaft for high powered applications. This requires a bearing change in the pinion support as well as a 35 spline pinion yoke. Gears termed 9-1/2" are also available for the 9" thirdmember. They offer a slight strength advantage over a standard 9" gear.
Re: Mark Williams Billet Caps for 8 3/4 [Re: TRENDZ] #1893109
08/16/15 07:04 PM
08/16/15 07:04 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Here...
Another thing with the 8 3/4.. they dont have many
gear choices in the pro gears.. I've always used the
street gear.. mainly due to the lack of pro gear choices
but they have been holding fine due to being a light car..
I have the street gears in my Rampage also because its 90%
street
wave
Re: Mark Williams Billet Caps for 8 3/4 [Re: runnerrt] #1893139
08/16/15 07:44 PM
08/16/15 07:44 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Good luck finding ANY ratio pro gears for an 8 3/4.
Re: Mark Williams Billet Caps for 8 3/4 [Re: TRENDZ] #1893143
08/16/15 07:46 PM
08/16/15 07:46 PM
MR_P_BODY Offline
MR_P_BODY  Offline
I dont even bother...I have been running the street
gears the whole time
wave
Re: Mark Williams Billet Caps for 8 3/4 [Re: TRENDZ] #1893443
08/17/15 05:23 AM
08/17/15 05:23 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Here...
I think everyone knows this........so was there a point to this?
Re: Mark Williams Billet Caps for 8 3/4 [Re: Monte_Smith] #1893451
08/17/15 08:13 AM
08/17/15 08:13 AM
W. Kentucky
justinp61 Offline
justinp61  Offline
W. Kentucky
Here...
No, not everyone knows. I've never ran or had the need to run pro gears so I didn't know what the difference.
Don't be a dick.
Re: Mark Williams Billet Caps for 8 3/4 [Re: runnerrt] #1893458
08/17/15 09:34 AM
08/17/15 09:34 AM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Just pulling back the curtain.
Re: Mark Williams Billet Caps for 8 3/4 [Re: runnerrt] #1893559
08/17/15 02:04 PM
08/17/15 02:04 PM
North Sweden
RT540 Offline
RT540  Offline
North Sweden
Ruined the teeth on two 489 Third members in one summer, early nineties.
Next winter I ordered a Dana 60 with spole and MW 35 splines axles from Mcandless in New York, problem solved.
440 ported 906 heads and 300hp top gun plate. All steel Road Runner 70. Street car.
Re: Mark Williams Billet Caps for 8 3/4 [Re: TRENDZ] #1893570
08/17/15 02:26 PM
08/17/15 02:26 PM
fredericksburg,va
cudaman1969 Online sleepy
cudaman1969  Online Sleepy
fredericksburg,va
Ok just throwing this out there, a lot of old timers swear by it. To soften the street gear so it won't shatter as much, heat in an oven to 425 degrees let cool slowly over a few hours. Poo-poo it or whatever. I didn't bother doing it, I just put the Dana in. 9 is a good rear, but for 1/4 the cost I'll use up my stuff first( maybe in my life time)
