Crank pulley for a Crank trigger??? #1892766
08/16/15 12:43 AM
08/16/15 12:43 AM
Portland, Oregon
Digger73 Offline OP
Digger73  Offline OP
Portland, Oregon
OK. I have been trying to find a crank pulley that will work with an MSD crank trigger. I have seen several in pictures posted here but no part numbers or information where I can get one. I need one for a BB that uses 6 bolt pattern and is a flat single groove. Any help would be great. I am trying to get the alt. mounted before I attempt to install the engine as it is way easier on the stand.
Thanks,
Digger73(Mike)
I live with fear everyday but, sometimes she lets me race!
Re: Crank pulley for a Crank trigger??? [Re: Digger73] #1892918
08/16/15 11:40 AM
08/16/15 11:40 AM
AndyF Offline
AndyF  Offline
You probably want the pulley from Doty Mfg.
Re: Crank pulley for a Crank trigger??? [Re: AndyF] #1893400
08/17/15 01:03 AM
08/17/15 01:03 AM
Portland, Oregon
Digger73 Offline OP
Digger73  Offline OP
Portland, Oregon
Andy you rock!
That's exactly what I am looking for. the web site seems to be under construction so I am unable to look up a part number. I will have to call them when I am off shift.
Thanks for the help,
Digger73 (Mike)
Re: Crank pulley for a Crank trigger??? [Re: Digger73] #1893413
08/17/15 01:42 AM
08/17/15 01:42 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
yes.... best to call Mancini, and get the flat one. They also have one with some offset built into it. I had the whole Michael Doty alt set up when I had my big block. Nice fitting well designed part.
Re: Crank pulley for a Crank trigger??? [Re: J_BODY] #1893471
08/17/15 09:40 AM
08/17/15 09:40 AM
Portland, Oregon
Digger73 Offline OP
Digger73  Offline OP
Portland, Oregon
So Mancini sells this pulley? If so, I will give them a call also. I saw some pulleys on their web site that looked like they might work but, there wasn't much of a description so I wasn't sure they were right.
Digger73 (Mike)
Re: Crank pulley for a Crank trigger??? [Re: Digger73] #1893505
08/17/15 11:05 AM
08/17/15 11:05 AM
aZLiViN
J_BODY Offline
J_BODY  Offline
aZLiViN
Re: Crank pulley for a Crank trigger??? [Re: J_BODY] #1893520
08/17/15 11:31 AM
08/17/15 11:31 AM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I wish I knew about that when I built my motor. I ended up making my own pulleys.
Re: Crank pulley for a Crank trigger??? [Re: markz528] #1893528
08/17/15 11:49 AM
08/17/15 11:49 AM
MR_P_BODY Offline
MR_P_BODY  Offline
I make up my own also... so I can get the ratio
that I want
wave
Re: Crank pulley for a Crank trigger??? [Re: MR_P_BODY] #1894118
08/18/15 12:43 AM
08/18/15 12:43 AM
Portland, Oregon
Digger73 Offline OP
Digger73  Offline OP
Portland, Oregon
I wish I had the talent to make my own pulleys. Those look great.
Digger73 (Mike)
