Carrier Stand for 8-3/4 Rebuild #1891903
08/14/15 05:02 PM
08/14/15 05:02 PM
Seattle, WA
rss Offline OP
rss  Offline OP
Seattle, WA
Thinking about freshening up my 8-3/4 and wondering what others may have used to hold the carrier during the teardown and reassembly process. I was thinking that I could fab up a couple of pieces that would allow me to attach it to my engine stand, but figured I would check around here to see what brilliant ideas others have used. If you have any, pics would be appreciated.
Re: Carrier Stand for 8-3/4 Rebuild [Re: rss] #1891944
08/14/15 06:26 PM
08/14/15 06:26 PM
Kirkland, Washington
Pacnorthcuda Offline
I just grabbed a piece of 1/4" scrap steel plate, about 6"x2" and drilled a few holes in it with the bolt spacing of the case. Had to clearance a bit for the ring gear. Bolt it to the case then chuck it in a vise---tight.
good to go.
Re: Carrier Stand for 8-3/4 Rebuild [Re: rss] #1892030
08/14/15 08:10 PM
08/14/15 08:10 PM
The Swamp
Sixpak Offline
Sixpak  Offline
The Swamp
I just built one myself from 1/2" galvanized threaded pipe. It's crude but it worked. I need to add some braces to it to form a triangle shape for more stiffness, but it worked.
Re: Carrier Stand for 8-3/4 Rebuild [Re: rss] #1892144
08/14/15 11:38 PM
08/14/15 11:38 PM
Pinelands , NJ
joelson6 Offline
joelson6  Offline
Pinelands , NJ
that works, great idea
Re: Carrier Stand for 8-3/4 Rebuild [Re: rss] #1892181
08/15/15 12:36 AM
08/15/15 12:36 AM
Andrews,In. U.S.of A.
67_Satellite Offline
I built one out of some old aftermarket spring shackles and other scrap i had. Made it so I could clamp it in the vise on the workbench, It doesn't roll around like an engine stand.
Re: Carrier Stand for 8-3/4 Rebuild [Re: rss] #1892428
08/15/15 02:43 PM
08/15/15 02:43 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I made this crude one 25 years ago and used it for years.
Then bought this one, it holds my cly heads too.
Re: Carrier Stand for 8-3/4 Rebuild [Re: Challenger 1] #1900880
08/28/15 03:04 AM
08/28/15 03:04 AM
Seattle, WA
rss Offline OP
rss  Offline OP
Seattle, WA
Lots of good ideas. Thanks for the responses!
Re: Carrier Stand for 8-3/4 Rebuild [Re: rss] #1900896
08/28/15 04:27 AM
08/28/15 04:27 AM
USA
rftroy Offline
rftroy  Offline
USA
Why spend your time and money when you can get this for just over 100?
http://www.summitracing.com/parts/otc-71...=MobileSwitchNo
Bolts on to your engine stand.
Robert
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: Carrier Stand for 8-3/4 Rebuild [Re: rftroy] #1901138
08/28/15 02:47 PM
08/28/15 02:47 PM
dogdays Offline
dogdays  Offline
Because some of us would rather spend that $100 on a billet metering block, something we can't make ourselves out of scrap.
R.
Re: Carrier Stand for 8-3/4 Rebuild [Re: rftroy] #1901580
08/29/15 12:46 AM
08/29/15 12:46 AM
mopar346 Offline
Let me tell ya about fat chicks!
mopar346  Offline
Robert
That would be about as difficult to make as a turkey cutout of your hand and not much more costly either. A piece of angle and then fab some forks or get them lazer cut for a reasonable price. twocents
Careful, your character's showing!
