Information I should have provided : A-833 4 speed, 3.55 sure-grip, and yes, initially it is a wheel hop issue. I've checked out the pinion snubber thing and the general opinion was it wouldn't be possible with the '36 Plymouth without a fair amount of modification. The springs, shackles, etc, are from Chassis Engineering. Since I had a shop do this part, I'm taking it on faith they got the right kit for the GTX.
I've had a suspicion the pinion angle is not correct. It's close, but not perfect.
On a 4 speed car that you want to use hard you should shoot for 4 to 7 degrees difference in the pinion shaft and driveshaft on the upper line, it should have a V there looking from the side
![up up](/ubbthreads/images/graemlins/custom/thumbs_up.gif)
Not a up side down V
![tsk tsk](/ubbthreads/images/graemlins/custom/tsk.gif)
As far as Mopar using pinion snubbers for traction that is a myth, the original cars (1957 and on)they came in had very little clearance between the driveshaft and the driveshaft tunnels, the snubbers where put in place to keep the pinion yokes and the driveshaft end from hitting the floors under hard acceleration comig off of dirt or wet roads or ice
![scope scope](/ubbthreads/images/graemlins/custom/scope.gif)
On your deal you need a special set of leaf prings made for your car from a high performance spring company or vendor like Tri City Performance
Chassis Engr. probally sold your shop a standard set of early street rod springs made for comfort, not high performance springs for high for performance driving like you need
![work work](/ubbthreads/images/graemlins/custom/work.gif)
Good luck, let us know what you do to fix it, that will help a lot of others street and hot rodders on here
