Page 2 of 3 1 2 3
Re: T&D rocker problem [Re: Al_Alguire] #1890671
08/12/15 11:47 PM
08/12/15 11:47 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
More
Re: T&D rocker problem [Re: oldguy] #1890672
08/12/15 11:51 PM
08/12/15 11:51 PM
Mich.
oldguy Offline OP
oldguy  Offline OP
Mich.
No but I can get some in the morning they are part#8210 which is what T&D said to order I don't know if Indy changed anything in there heads along the way these are from 1999 or so big offset intake rocker straight up exhaust.
Re: T&D rocker problem [Re: oldguy] #1890674
08/13/15 12:00 AM
08/13/15 12:00 AM
glendora, ca.
Deepockets Offline
Deepockets  Offline
glendora, ca.
Looks like the wear in the cup is really offset towards the inside. Like said earlier, it may be rubbing some ware thru it's cycle. Also, is the pushrod correct for the cup diameter?
Re: T&D rocker problem [Re: oldguy] #1890688
08/13/15 12:18 AM
08/13/15 12:18 AM
Mich.
oldguy Offline OP
oldguy  Offline OP
Mich.
The push rod actually pops out of the cup there are 5/16 ball with a .210* radius they push out toward the shaft at the beginning of lift.
Re: T&D rocker problem [Re: oldguy] #1890723
08/13/15 12:43 AM
08/13/15 12:43 AM
Mich.
oldguy Offline OP
oldguy  Offline OP
Mich.
I coped this from another site so were not the only ones having this issue.
We tried to use T&D's but kept breaking parts... We tried to use T&D's but kept breaking parts with them, couldn't get the pushrods to stay in the ajusters for whatever reason. Got tired of them, sold them and bought a set of Harlan Sharps instead....
Re: T&D rocker problem [Re: oldguy] #1890772
08/13/15 02:06 AM
08/13/15 02:06 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
And FWIW I have NEVER broken a T&D part and most here would think we run pretty high spring loads, up to 1270lbs open. Everything has to be correct if you are having an issue like this there is something not right.
Re: T&D rocker problem [Re: Al_Alguire] #1890860
08/13/15 10:15 AM
08/13/15 10:15 AM
s.w.fl
bonefish Offline
bonefish  Offline
s.w.fl
do your ex rockers have a right and left offset?
Re: T&D rocker problem [Re: oldguy] #1890868
08/13/15 10:39 AM
08/13/15 10:39 AM
oh
julian2007 Offline
julian2007  Offline
oh
I have the very same problem with a set of -1 heads
I for get the exact lash but what we found was the lash was too loose and it let the push rod drop and work on the cup.
I lashed them .005 tighter and fixed the problem.
what is your lash procedure? ie temp, how much ect.
Sorry I don't know you and not to sound like a ass but you cannot lash them cold per card specs if you do on t&d's you will have that exact problem when it gets hot they will be way too loose and destroy the edge of the cup. Those heads will grow quite a bit when you warm them up and you will loose lash
Again I had the same problem we were trying different setups and got them too loose and it did the same thing.
Bruce
God made cold beer,good friends,hot ladies and race cars don't spit in his face by pi$$ing and moaning about how life sucks!!!
Re: T&D rocker problem [Re: oldguy] #1891027
08/13/15 02:42 PM
08/13/15 02:42 PM
Mich.
oldguy Offline OP
oldguy  Offline OP
Mich.
Julian thanks for your post we closed the lash up to .010 cold still doing it but it does seem better. I'm going to send more pic's to Al maybe he will post them for me I'm not saying the T&D rockers are bad I'm just looking to correct the issue.
Re: T&D rocker problem [Re: oldguy] #1891049
08/13/15 03:25 PM
08/13/15 03:25 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
More pics
Re: T&D rocker problem [Re: oldguy] #1891051
08/13/15 03:26 PM
08/13/15 03:26 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
The rocker is not riding off the backside of the stem is it??? Sure looke like it might be getting close. How does the sweep look?
Re: T&D rocker problem [Re: Al_Alguire] #1891082
08/13/15 04:31 PM
08/13/15 04:31 PM
oh
julian2007 Offline
julian2007  Offline
oh
what are you lashing them at?
Re: T&D rocker problem [Re: julian2007] #1891087
08/13/15 04:35 PM
08/13/15 04:35 PM
oh
julian2007 Offline
julian2007  Offline
oh
sorry re read your post .010 cold. aluminum block or iron? what are they growing too?
Re: T&D rocker problem [Re: oldguy] #1891130
08/13/15 05:11 PM
08/13/15 05:11 PM
Mich.
oldguy Offline OP
oldguy  Offline OP
Mich.
Sorry we have not checked them hot with this set up the old stuff grew about .006 the card called for .028 lash so we closed it up a lot Iron block
Re: T&D rocker problem [Re: oldguy] #1891212
08/13/15 07:27 PM
08/13/15 07:27 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
More
Re: T&D rocker problem [Re: oldguy] #1891223
08/13/15 07:35 PM
08/13/15 07:35 PM
Milwaukee WI
TRENDZ Offline
TRENDZ  Offline
Milwaukee WI
Well, the pushrod tips and the adjusters that that happened to are not usable anymore. Those adjusters are shallow to begin with, and now they are damaged enough that even tighter lash will likely not solve the problem.
New pushrods and adjusters with tighter lash settings will fix ya up. The only way that would happen is if either the pushrod is contacting something and deflecting it, or the lash is to wide at the temps it runs.
Re: T&D rocker problem [Re: TRENDZ] #1891384
08/13/15 10:30 PM
08/13/15 10:30 PM
Mt. Vernon, Ohio
dartman366 Offline
dartman366  Offline
Mt. Vernon, Ohio
looks to me like the rocker shaft needs to be raised, tip is too inboard on the tip at no lift and the roller is to far out at lift, looks like the geometry is off, should be more centered to the valve tip at both ends of the sweep and the roller in the center at mid lift,,just my opinion your opinions may vary.
Re: T&D rocker problem [Re: oldguy] #1891462
08/13/15 11:48 PM
08/13/15 11:48 PM
Mich.
oldguy Offline OP
oldguy  Offline OP
Mich.
Trendz the adjusters were changed every time we tried something different and no there not hitting anything it's simply the angle between the push rod and adjuster. I'm going to try a rocker with the 4* different angle it's more inline with the push rod you can only tighten the lash so much.
Dartman I moved the shaft up before and I may try that again.
Thanks everyone for your thought's and thank you Al for posting the pic's
Re: T&D rocker problem [Re: dartman366] #1891468
08/13/15 11:59 PM
08/13/15 11:59 PM
USA
B3RE Offline
B3RE  Offline
USA
I agree, the shaft needs to be raised considerably. We may disagree on the sweep, but right now it has to be over .100". For example, even a net valve lift of .750" will have less than .050" sweep when properly set up. Raising the shaft will also straighten the pushrod out when the valve is on the seat.
Mike Beachel
I didn't write the rules of math nor create the laws of physics, I am just bound by them.
Re: T&D rocker problem [Re: Al_Alguire] #1891470
08/14/15 12:01 AM
08/14/15 12:01 AM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
Originally Posted By Al_Alguire
... if you are having an issue like this there is something not right.
X2
Has the problem been discussed with T&D?
Page 2 of 3 1 2 3
