Re: Any place to get new door glass for a 70s truck?
[Re: 5thAve]
#1892276
08/15/15 08:30 AM
08/15/15 08:30 AM
Posts: 5,885 ohio
ruderunner
ohio
Vent window assemblies changed a couple times from 72-93 but I'm not sure if that made changes to the door glass.
Also the lower sash changed a couple times as did the regulator, iirc the difference is the size of the roller.
Can you post pics of how the window doesn't fit?
I'll try to measure some doors to see if I çàn spot some difference in glass opening.
Angry white pureblood male
[Re: 5thAve]
#1892656
08/15/15 10:45 PM
08/15/15 10:45 PM
Posts: 5,885 ohio
ruderunner
ohio
Not sure what the roof has to do with the door glass.
Is the glass actually going all the way up the channel?
Starting to sound like sloppy install.
[Re: 5thAve]
#1892828
08/16/15 07:56 AM
08/16/15 07:56 AM
Posts: 5,885 ohio
ruderunner
ohio
Ahhhh, no the door opening didn't change shape. Not all trucks got the squared off roof. Crew cabs, extended cabs ketp the same roof. You can swap doors between the cabs, just need the fenders so the body Ines match up.
So I think it's time to pop a door panel and have a look at adjustment for the glass, specifically if there is an up stop.
This is on just one side correct?
