2014 Challenger no oil change indicator function
#1890851
08/13/15 09:37 AM
08/13/15 09:37 AM
Posts: 10,847 Oakdale CT
gdonovan
Oakdale CT
Both my Challenger and my wife's Avenger state they have oil change warning system and yet neither car does the system seem to function.
On the Avenger it is suppose to come up with "oil change" in the cluster and never did even when the car hit 9000 miles and I changed the oil.
On the Challenger it is suppose to be part of the clusters information system and yet I cannot access the oil change menu as the manual states you can.
Has anyone else run across this? I'm going to call the dealer today to follow up.
Gary
"I think its got a hemi"
Re: 2014 Challenger no oil change indicator function
[Re: gdonovan]
#1890852
08/13/15 09:45 AM
08/13/15 09:45 AM
gdonovan
Oakdale CT
Called the dealer, that was somewhat waste of time.
You will have to bring it in so our techs can look at it..
[Re: gdonovan]
#1890907
08/13/15 11:47 AM
08/13/15 11:47 AM
gdonovan
Oakdale CT
No info screen on Challenger or Avenger even though the manual states the Challenger should have one. Avenger hit 9000 with no chime nor warning.
My Challenger is over by time by a few months, still no message with 6300 on the clock.
[Re: burdar]
#1890963
08/13/15 01:00 PM
08/13/15 01:00 PM
gdonovan
Oakdale CT
The Sebring doesn't have an "info center" per say either. I guess it just scrolls across the screen that displays what gear the trans is in. The Avenger should be the same I would think. Correct. On her car the odometer numbers are suppose to change to a "calculator style" text message for oil change. You know, like when you would spell out "boobies" with a calculator in high school.
[Re: Paul_Fancsali]
#1891134
08/13/15 05:24 PM
08/13/15 05:24 PM
gdonovan
Oakdale CT
My 2009 comes on between 2200 miles and 3600 miles even with synthetic oil and looks perfectly clean I do it anyway I do a LOT of short term city driving with little highway time to burn off contaminates. Its only a 10 minute drive to work so its pretty much worse case for oil changes short of dusty driving conditions.
