Re: 518 to OD833 behind my BB 86 RC
[Re: Robbins]
#1910305
09/11/15 12:01 AM
09/11/15 12:01 AM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
I guess I'm not going to run that all cast iron one until I go threw it.....I'm going to put the 80 one out of the swb.
Moparlee
[Re: Robbins]
#1910311
09/11/15 12:07 AM
09/11/15 12:07 AM
Robbins
Joplin, MO USA
I wish I had the money for a set of 3.54's.
Moparlee
[Re: Robbins]
#1914984
09/18/15 12:41 PM
09/18/15 12:41 PM
Robbins
Joplin, MO USA
This is the first for a lot of things for me....one is I will be using a Timken through out bearing and pilot bearing....hope it works out for me.
Moparlee
[Re: Robbins]
#1914993
09/18/15 12:46 PM
09/18/15 12:46 PM
Robbins
Joplin, MO USA
So far so good on using the 518 crossmember......lots of room to get to everything.
Moparlee
[Re: Robbins]
#1915005
09/18/15 12:53 PM
09/18/15 12:53 PM
Robbins
Joplin, MO USA
I'm guessing that the two wheel drive RC/TD's had shims between the crossmember & frame is cause of the shorter wheel base than the short bed trucks.....but I'm hoping it's not going to affect the height of the shifter to much.
Moparlee
[Re: Robbins]
#1918296
09/23/15 07:22 PM
09/23/15 07:22 PM
Robbins
Joplin, MO USA
Still plugging away at it. The rearend cover had a leak....Sure Grip from Dr. Diff. I made a gasket between the floor and the fiber hump....I hope it works. More pictures to come.
Moparlee
[Re: Robbins]
#1918459
09/23/15 11:13 PM
09/23/15 11:13 PM
Robbins
Joplin, MO USA
She had some light paint bubbles going on took a wire wheel to them.....glad I did.....some hidden surface rust.
Moparlee
