518 to OD833 behind my BB 86 RC
#1739082
01/26/15 03:00 PM
01/26/15 03:00 PM
Posts: 4,920 Joplin, MO USA
Robbins
Joplin, MO USA
Got the carpet pulled up so far...I was surprised to how nice my 28 year old floor board looked up front.
Moparlee
Re: 518 to OD833 behind my BB 86 RC
[Re: Robbins]
#1739084
01/27/15 12:36 AM
01/27/15 12:36 AM
Robbins
Joplin, MO USA
Trans & bellhousing that I'm going to be useing..
Moparlee
[Re: Robbins]
#1739085
01/27/15 02:55 PM
01/27/15 02:55 PM
Posts: 3,886 Lost and Spaced
bboogieart
Lost and Spaced
Very solid looking. Good start. I'll be watching this one. I want to do something similar in a 76. It already has a 4 speed, but it's a granny gear set-up. Where did you get the hump? Come with the trans? Could you please mention where every thing came from. Thanx tons.
I have mechanical Aptitude. I can screw up anything.
[Re: bboogieart]
#1739086
01/27/15 02:58 PM
01/27/15 02:58 PM
Robbins
Joplin, MO USA
Are you talking about the black fiber glass piece...from a salvage yard....I have another one if you need one. I forget where I got the bell from...hard to find...there is a sight that still has it listed for sale....but expensive....I paid a little less, but not much.....my Dad ran that trans in a 71 pickup back in the day.
Moparlee
[Re: Robbins]
#1739087
01/27/15 03:19 PM
01/27/15 03:19 PM
bboogieart
Lost and Spaced
Yeah I meant the fiberglass part. P.M. me I wont need pedals but linkage, drive, shaft and the rest. I would imagine most would be sourced at the pick n pull. What year trucks should I be looking for? Hopefully I could get it all from the same truck. I'm probably gonna use a 360 I have laying around. I wanted to follow along as the rest will be the similar enough.
[Re: Robbins]
#1887000
08/07/15 05:27 PM
08/07/15 05:27 PM
Robbins
Joplin, MO USA
Well I finally getting this done.....what do you guys recommend for sealing the floor around the the reinforcement plates for the z-bar.
Moparlee
[Re: Robbins]
#1887568
08/08/15 05:34 PM
08/08/15 05:34 PM
Posts: 1,357 central Florida
VL21
central Florida
Not sure about pic posting ... I'll try ...
worked that time. There are several steps to it, and I usually forget one ...
It takes gasoline to interest me.
[Re: Robbins]
#1887722
08/08/15 10:41 PM
08/08/15 10:41 PM
Robbins
Joplin, MO USA
The carpet actually had cut outs of a truck four speed and the 4x4 shifter, but not for the car four speed hole....oh well....still cool that it had those two items.
Hello...got it figured out....derrr....lol
Moparlee
[Re: Robbins]
#1887725
08/08/15 10:43 PM
08/08/15 10:43 PM
Robbins
Joplin, MO USA
Getting ready to swap the peddles out here and drill the holes for the reinforcement plate.
Moparlee
[Re: Robbins]
#1887741
08/08/15 10:53 PM
08/08/15 10:53 PM
Robbins
Joplin, MO USA
Well I finally getting this done.....what do you guys recommend for sealing the floor around the the reinforcement plates for the z-bar. Any ideas?
Moparlee
[Re: Robbins]
#1887749
08/08/15 10:55 PM
08/08/15 10:55 PM
Robbins
Joplin, MO USA
In this pix you can see the swing set hanging also already.
Moparlee
[Re: Robbins]
#1887751
08/08/15 10:56 PM
08/08/15 10:56 PM
Robbins
Joplin, MO USA
top plate down also in this picture I still need to unscrew the plate for the clutch rod to go threw.
Moparlee
[Re: savoy64]
#1889547
08/11/15 03:36 PM
08/11/15 03:36 PM
Posts: 760 Canada
CTD5.9
Canada
so did that 833 come off a chevy diesel truck?----i have never heard of one on a dodge unit as a 4x4 setup.... I downloaded the picture, looks like a car/2wd 833 to me
