Re: Broke the rocker stand stud and T&D rocker shaft.
[Re: 451Mopar]
#1890266
08/12/15 02:30 PM
08/12/15 02:30 PM
BradH
... or is there a problem running about 770+ open spring pressures on these Victor heads? Got me, but that's some serious spring pressure for a street-driven car IMHO. I'm only going to be running about 600#s open and am already concerned if I'll encounter any shaft mounting issues w/ my Victors.
[Re: BradH]
#1890397
08/12/15 05:39 PM
08/12/15 05:39 PM
Posts: 3,667 Arizona
Chris'sBarracuda
Arizona
Better check w/ T&D on how much torque they want to see used w/ their shafts. Just because ARP says 50#s doesn't mean the shafts can stand up to that much w/o getting "squished" out of round at the mounting points. He uses rocker stands. Shouldn't apply. Chris. .
[Re: Chris'sBarracuda]
#1890443
08/12/15 06:38 PM
08/12/15 06:38 PM
BradH
Better check w/ T&D on how much torque they want to see used w/ their shafts. Just because ARP says 50#s doesn't mean the shafts can stand up to that much w/o getting "squished" out of round at the mounting points. He uses rocker stands. Shouldn't apply. You don't think those aluminum stands will distort if torqued too much? Maybe he needs to check w/ the maker of the stands on how they think 50#s will work out. You may be 100% right, but having ovaled good shafts using nice steel hold-downs and far less torque, I'm a lil' suspect.
[Re: 451Mopar]
#1890484
08/12/15 07:48 PM
08/12/15 07:48 PM
Posts: 5,399 Aurora, Colorado
451Mopar
Aurora, Colorado
I doubt I will be using 50 ft/lbs, but I'm not too worried about getting the shaft out of round. These shafts are smaller diameter and thick material when compared to the stock sized rocker shafts, but this also presents a different issue relating to oiling through the rocker shaft. The three inner studs have a reduced diameter so oil can flow around them, so they will have to be torqued to a lower setting. It is interesting none of those broke?
I E-Mailed Jesel to see what they have, and this is their reply:
"We do a pro series rocker kit for that head. There is machining required. The factory style cast in rocker shaft pedestals have to be removed for our steel stand to bolt down to the head. Then our shaft bolts to our steel stand. The rocker kit costs $1700.00 and takes about 7-10 days to build to your desired ratio.
Jon Fodor JESEL, Inc. 732-901-1800 xt. 161 732-901-6777 fax jonf@jesel.com"
For someone thinking of using these heads and looking for a rocker system, the Jesel setup may be the way to go? The T&D system is almost $1200, then I spent another $200+ on the aluminum stands and hardware, so their rocker kit would not be much more than what I already have in my T&D setup?
