header gasket #1888504
08/10/15 12:54 AM
08/10/15 12:54 AM
NEW JERSEY
dynamite Offline OP
dynamite  Offline OP
NEW JERSEY
Who's header gasket do you guy's use.??? I keep blowing them out after a few days of street driving.. I've tried to make the header smooth to the head but The stock crap the locals sell just won't hold .. any suggestions ?? BR /aluminum heads...
Re: header gasket [Re: dynamite] #1888513
08/10/15 01:09 AM
08/10/15 01:09 AM
"ultra seals" get rave reviews on here (I forget the brand). I would drawfile the welded beads some more (get em good and flat) and cut the flat flange so each tube is independent
Re: header gasket [Re: dynamite] #1888531
08/10/15 01:29 AM
08/10/15 01:29 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
We run Mr Gasket Ultra seals also.Ive had headers off and on and reused them.My kid did blow one out after about 6 years and after I reused them.Mine have been on at least 6 years.I run TTIS but we ran them with Summits cheap headers and no problems.Rocky
Chrysler Firepower
Re: header gasket [Re: RapidRobert] #1888538
08/10/15 01:35 AM
08/10/15 01:35 AM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
I have had my share of header gasket sealing issues years ago so now before I install a set I put ink on the header sealing surfaces and very lightly hand file them one at a time in an x-pattern with the widest file I have until the ink is gone. I can get years of use out of the cheapo white Mr Gasket paper gaskets once the header sealing surfaces have been hand filed flat.
If you don't want to pull the headers out to file them then adding a thin coat of copper rtv to any gasket helps seal up any small imperfections.
The most bulletproof gasket setup I'm aware of is copper gaskets along with copper rtv.
Re: header gasket [Re: dynamite] #1888624
08/10/15 09:49 AM
08/10/15 09:49 AM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
Mr gasket ultraseal
Napa nitroseal
Remflex
Copper
No gasket, just high temp rtv
Not necessarily in that order
Re: header gasket [Re: GomangoCuda] #1889145
08/10/15 11:09 PM
08/10/15 11:09 PM
South San Francisco, Californi...
MidPenMopar Offline
Looking for fun? Keep looking
MidPenMopar  Offline
Remflex!
Re: header gasket [Re: therocks] #1889212
08/11/15 12:29 AM
08/11/15 12:29 AM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Good luck here as well. Do pay attention to the leaking gasket pattern, IE: port, to flange, to gasket size. Sometimes one of the three is mis-matched size wise
twocents
Re: header gasket [Re: TJP] #1889229
08/11/15 01:05 AM
08/11/15 01:05 AM
IN
ahy Offline
ahy  Offline
IN
No gasket has worked well for me. Just a little high temp orange RTV. Needs reasonably flat flanges and correct fit as mentioned.
With no gasket and good fit there is almost nothing to blow out = no leaks.
Re: header gasket [Re: dynamite] #1889331
08/11/15 08:58 AM
08/11/15 08:58 AM
bethlehem pa
mikemee1331 Offline
mikemee1331  Offline
bethlehem pa
gonna try those Mr. Percy aluminum ones in a couple of weeks. i have always had good luck in the past with the Ultra-Seals but you gotta remember to re-torque the bolts/nuts.
Re: header gasket [Re: dynamite] #1889432
08/11/15 12:39 PM
08/11/15 12:39 PM
md
mopars4ever Offline
mopars4ever  Offline
md
8 years with the same header gasket that came with my TTI`s. Don`t know what brand they were. Never even retorqued.
Re: header gasket [Re: dynamite] #1889451
08/11/15 12:59 PM
08/11/15 12:59 PM
Las Vegas
JeffC Offline
JeffC  Offline
Las Vegas
For hard to seal headers, I've always used felpro's doubled up never had one blow out.
Re: header gasket [Re: dynamite] #1889454
08/11/15 01:03 PM
08/11/15 01:03 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
I used the TTIs for a few years also.Had to replace them when I changed heads.I used coppers and Percys.Both leaked.The coppers do seal good on my collectors.If you can run cheap headers with Ultras and they seal they must be good.Ran like 3 cheap sets and all sealed.Rocky
Chrysler Firepower
Re: header gasket [Re: dynamite] #1889476
08/11/15 01:43 PM
08/11/15 01:43 PM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
REMFLEX!
I typically don't have much issue with my Hookers, but the old junk headmans I had on my 383 were a nightmare, UNTIL I found Remflex!
Re: header gasket [Re: dynamite] #1889522
08/11/15 03:08 PM
08/11/15 03:08 PM
How thick are your header flanges at the head? Are they one piece or three? I've heard of guys having sealing issues on the flanges to the head cut them and that fix the problems they had confused shruggy I've done that on Hooker A body BB fenderwells and that worked well up
Re: header gasket [Re: dynamite] #1889570
08/11/15 04:22 PM
08/11/15 04:22 PM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
A few sets we used had the thin flanges.Two sets are thick like my TTIs.I did cut my TTIs just for clearance.The cheap ones I didnt bother and they sealed.Some were SB some BB.Rocky
Chrysler Firepower
Re: header gasket [Re: dynamite] #1889590
08/11/15 05:15 PM
08/11/15 05:15 PM
Ohio
jlatessa Offline
jlatessa  Offline
Ohio
I agree with Cab, I always have cut the flanges in two places each
and have had no problems.
It allows the header flange surfaces to more easily conform to the head, try it, you'll like it....
Joe
Re: header gasket [Re: jlatessa] #1889725
08/11/15 08:21 PM
08/11/15 08:21 PM
Virginia
HemiStan Offline
HemiStan  Offline
Virginia
REMFLEX!
I have yet to find a set of headers that a set of Remflex gaskets could not seal. I am not kidding. They are the only set of header gaskets that I will purchase.
Stan
