Help with wiring diagram #1889277
08/11/15 02:10 AM
08/11/15 02:10 AM
Omaha, Nebraska
Scott Carl Offline OP
Omaha, Nebraska
Has anyone had any problem reading MyMopar.com wiring diagrams? I'm trying to diagnose an ignition issue and studying the diagram for my 74 challenger. On nearly every diagram I have looked at, only E-bodies have a second wire on the neg side of the coil. The first one, a black and yellow, goes to the ECU which seems common to the other diagrams. But the second wire (than other non-ebody diagrams don't have, traces down to the bulkhead connector but there is nothing connected to it on the other side. What's up with that?? I can't say for sure now (Its dark now) if mine, indeed actually has this gray wire. The only gray wire I'm sure about is the one that goes from sender to oil press gauge.
Anyone else have problems with mymopar.com's wiring diagrams?? shruggy
Scott
Re: Help with wiring diagram [Re: Scott Carl] #1889281
08/11/15 02:15 AM
08/11/15 02:15 AM
that extra wire on the coil neg pri would have to be the sense wire for the tach
Re: Help with wiring diagram [Re: Scott Carl] #1889287
08/11/15 02:27 AM
08/11/15 02:27 AM
bc
3
37dodge Offline
37dodge  Offline
bc
The brown wire cames off the gray and goes to the tac on the 74 rr http://www.mymopar.com/downloads/1974/74SatelliteRoadRunnerA.JPG
Re: Help with wiring diagram [Re: Scott Carl] #1889294
08/11/15 03:15 AM
08/11/15 03:15 AM
Omaha, Nebraska
Omaha, Nebraska
D'oh! Now there's an "Ah ha" moment!! laugh
Scott
Re: Help with wiring diagram [Re: Scott Carl] #1889320
08/11/15 07:31 AM
08/11/15 07:31 AM
Balt. Md
3
383man Offline
383man  Offline
Balt. Md
For me it would be a "Da" moment as I seem to have more of them as I get older. Ron
Re: Help with wiring diagram [Re: Scott Carl] #1889341
08/11/15 09:45 AM
08/11/15 09:45 AM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
Those are basic diagrams. Check the FSM for a more detailed easier to read breakdown and it'll also have separate accessory diagrams for tach wiring.
Re: Help with wiring diagram [Re: Scott Carl] #1889813
08/11/15 09:57 PM
08/11/15 09:57 PM
Fresno, CA
Jim_Lusk Offline
Jim_Lusk  Offline
Fresno, CA
I can tell you why those diagrams do not have the tach wire going to the tach. Those diagrams were taken from a CD that I put together several years ago from mostly National Service and Mitchell manuals. Those manuals did not include rallye dash wiring. You will find the rallye dash wiring in their 1970 diagrams as that is from a factory manual.
Yes, I copied those diagrams and sold the CDs. One of their members bought a CD and immediately published them on the MyMopar site.
