Re: jack stand palcement [Re: shorthorse] #1890859
08/13/15 10:14 AM
08/13/15 10:14 AM
Up a holler, down a crick
booger Offline
booger  Offline
Originally Posted By shorthorse
[quote=D_C]Sometimes, I have used metal drive-on ramps, backward (with the ramp end forward). I use a floor jack to lift beneath the K-Member and place the ramps in position under each tire (as I said) long end forward (toward the front bumper) to be out of the way.
Me too. I also jack up the rear end and stick stands under the axle housing. You can never have too much room under there. Automatics are worse.
Chasing bears through the woods drunk with a dull hatchet is strongly not advised
Re: jack stand palcement [Re: Supercuda] #1891048
08/13/15 03:25 PM
08/13/15 03:25 PM
Ohio
shorthorse Offline
shorthorse  Offline
Ohio
Originally Posted By Supercuda
I flattened one of those metal ramps with my 64 300, after I had already parked on it and got out. Since then, no thank you, I use the plastic ones when I use a ramp.
Your right. I've since purchased 2 sets of the plastic ramps. They are good for something like 16,000 pounds. Got one set on Craigslist for $20.
Re: jack stand palcement [Re: mickm] #1891743
08/14/15 11:40 AM
08/14/15 11:40 AM
Pikes Peak Country
TC@HP2 Offline
TC@HP2  Offline
Pikes Peak Country
Reinforced drive up ramps with removable incline:
http://www.northerntool.com/shop/tools/product_200641867_200641867?cm_mmc=Google-pla&utm_source=Google_PLA&utm_medium=Automotive%20%3E%20Ramps&utm_campaign=Ironton&utm_content=47112&ci_src=17588969&ci_sku=47112&gclid=CJin-efZqMcCFQenaQodoFQCfA
(dang, can't get it to hyperlink)
or these:
https://usahardware.com/departments/automotive/jacks-stands-ramps/magnum-poly-car-ramps.html
or even these:
http://www.raceramps.com/
