Try to find out exactly where the oil is coming from
The oil leaking from the rear main seal will possibly be on the front of the clutch inspection cover and definetly on the front of the flywheel slung out into the bellhousing
I've seen valve cover leaks and oil leaking from the back of the intake valley pan make some guys thing they had a rear main seal leaking, lots of gremlins out there on new builds
Hopefuy it is not leaking from the cam plug in the rear of the motor above the crankshaft
Good luck
Let us know what you find and do to fix it.
