Front Strut Rod Bolt Torque 70 Challenger? #1883420
08/02/15 11:20 AM
08/02/15 11:20 AM
US
f2502011 Offline OP
f2502011  Offline OP
US
What's the torque spec for the front strut rod bolt on a 1970 Challenger?
1970 EK2 T/A 727
Re: Front Strut Rod Bolt Torque 70 Challenger? [Re: f2502011] #1883461
08/02/15 12:33 PM
08/02/15 12:33 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Be more specific, there is no bolt on a strut rod. Do you mean where the rod is connected to the lower control arm, or the big nut at the front?
Re: Front Strut Rod Bolt Torque 70 Challenger? [Re: f2502011] #1883491
08/02/15 01:16 PM
08/02/15 01:16 PM
S. Il. U.S.A.
5spdcuda Offline
5spdcuda  Offline
S. Il. U.S.A.
105 ft. lbs. at the control arm end and 55 ft. lbs. at the front or "K" frame end.
Re: Front Strut Rod Bolt Torque 70 Challenger? [Re: 5spdcuda] #1883517
08/02/15 01:56 PM
08/02/15 01:56 PM
Morristown Tn.
71birdJ68 Offline
71birdJ68  Offline
Morristown Tn.
Also, you do not tighten the front nut on the strut rod until after the ride height has been set. Same goes for the lower control arm pin that goes through the K frame, or it will rip the bushing loose.
