Does engine oil have a shelf life? #1883045
08/01/15 07:52 PM
08/01/15 07:52 PM
Central Florida
larrymopar360 Offline OP
Stud Muffin
Stud Muffin
Central Florida
I've had some conventional oil around for over a year. Bought it earlier than I should have, and probably won't need to use it for another year or so. Long story.
Do you think I should recycle it and buy new when I'm ready?
Thanks.
Facts are stubborn things.
Re: Does engine oil have a shelf life? [Re: larrymopar360] #1883047
08/01/15 07:54 PM
08/01/15 07:54 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Oil won't go bad in a year or two. I don't think it ever really goes bad.
Re: Does engine oil have a shelf life? [Re: larrymopar360] #1883050
08/01/15 07:56 PM
08/01/15 07:56 PM
USA
rftroy Offline
rftroy  Offline
USA
5 years. You will find other companies give the same 5 year number for sealed containers.
http://www.mobilindustrial.com/ind/engli...mmendations.pdf
Robert
AAR 4-speed 3.91, Tor-Red;
70 440 6 pack Roadrunner 4-speed 3.54, Plum Crazy;
68 Formula S conv 383 4-speed 3.23, Electric Blue;
69 Barracuda conv Slant 6 OD4 2.94, 71 B5 Blue;
78 Lil' Red Truck, Red;
70 Challenger S/E. 505 6 pack, Passon 5-speed, 3.55, B7 Blue
Re: Does engine oil have a shelf life? [Re: larrymopar360] #1883053
08/01/15 08:00 PM
08/01/15 08:00 PM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
Great, thank you.
Re: Does engine oil have a shelf life? [Re: larrymopar360] #1883161
08/01/15 11:13 PM
08/01/15 11:13 PM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Oil should not go bad, unless used, it's been in the ground over million years. There's people that believe water goes bad.
Re: Does engine oil have a shelf life? [Re: Car Nut] #1883186
08/01/15 11:51 PM
08/01/15 11:51 PM
Kirkland, Washington
Pacnorthcuda Offline
You bet it does. We have oils and lubes that go out-of-service and have to pay hazmat bucks to dispose. I recall 2 years as being the point where they are no longer returnable to the manufacturer.
Would I use it beyond a 2 year shelf life date?--oh hell yea.
Additive packages.
Re: Does engine oil have a shelf life? [Re: larrymopar360] #1883208
08/02/15 12:22 AM
08/02/15 12:22 AM
Central Florida
Stud Muffin
Stud Muffin
Central Florida
I figured that the additives may break down, or as mentioned in article rftroy linked, it can accumulate moisture.
Re: Does engine oil have a shelf life? [Re: larrymopar360] #1883229
08/02/15 12:52 AM
08/02/15 12:52 AM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
It can only gather moisture if it has been unsealed.
Re: Does engine oil have a shelf life? [Re: larrymopar360] #1883252
08/02/15 01:19 AM
08/02/15 01:19 AM
Pacific NW USA
CompSyn Offline
CompSyn  Offline
Pacific NW USA
I e-mailed Shell about this question. This was their response:
The shelf-life on properly stored, unopened motor oil is 4 years, After that time, the oil should be properly disposed of at an oil recycle location.
Doug Hund
Shell Lubricants
Business to Business Account Manager
700 Milam, Suite #18016
Houston, TX 77002
doug.hund@shell.com
Off - (713) 546-4498
Cell - (713) 398-6510
Fax - (713) 217-3439
If you want to know the reasoning, I'd imagine Mr. Hund would be a good resource.
Re: Does engine oil have a shelf life? [Re: larrymopar360] #1883263
08/02/15 01:40 AM
08/02/15 01:40 AM
5thAve Offline
5thAve  Offline
Like what was mentioned it's the additives that have the problem, not the oil itself.
I have a jug that's several years old and you can see how the different parts have separated.
Re: Does engine oil have a shelf life? [Re: stumpy] #1883285
08/02/15 02:05 AM
08/02/15 02:05 AM
I have seen sealed container have condensation in them, both plastic and metal shock I have save oil that had water in it by heating up to around 212 F, the water will settle to the bottom of the container as it heats up and then bubble as it turns to steam, keep the lid on until all the water is steamed out up Do not let the boiling bubbling steam from the water make the hot oil get onto a heating devices tsk, It will ignite and burn shock Don't ask me how I kow about that whistling realcrazy
Re: Does engine oil have a shelf life? [Re: larrymopar360] #1883311
08/02/15 02:48 AM
08/02/15 02:48 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
The plastic oil containers have a Moisture Vapor Transmission Rate (MVTR). MVTR is a measure of the passage of gaseous H2O through a barrier. The lower the rate, the longer the package protects its contents from moisture and ensures the moisture content of the product remains the same.
IOW, moisture permeates the walls of the sealed plastic container and enters the contents; the moisture doesn't affect the oil as much as it does the additives in the oil, especially calcium which absorbs the moisture and causes the calcium to drop out of suspension. That's why many refiners recommend inspecting the bottom of the container for small whitish particles, that's the calcium that has dropped out of suspension....don't use such oil.
Re: Does engine oil have a shelf life? [Re: larrymopar360] #1883327
08/02/15 03:44 AM
08/02/15 03:44 AM
Zombieland
Car Nut Offline
Car Nut  Offline
Zombieland
Thanks larrymopar360 for asking this question, very good answers guys.
Re: Does engine oil have a shelf life? [Re: larrymopar360] #1883364
08/02/15 09:37 AM
08/02/15 09:37 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
I am still using 20 year old oil, some is 15 years old and some is 20 years old. I have been using it in 4 vehicles and a lawn mower and generator and more since the late 80s early 1990. No trouble here.
Re: Does engine oil have a shelf life? [Re: larrymopar360] #1883396
08/02/15 10:36 AM
08/02/15 10:36 AM
Niles , Ohio
therocks Offline
therocks  Offline
Niles , Ohio
Challanger I agree.I bought some oil and trans fluid that was at least 20 years old.Used them and they were as good as if I had just bought them.I should have saved the old can they were in.Rocky
Chrysler Firepower
Re: Does engine oil have a shelf life? [Re: larrymopar360] #1884056
08/03/15 02:07 AM
08/03/15 02:07 AM
E. Okla line
m88mark Offline
m88mark  Offline
E. Okla line
Bought 12 drums of surplus mil spec 15/40 in the 80's. On my last 55 gal. I sure am gonna hate buying oil.
Re: Does engine oil have a shelf life? [Re: larrymopar360] #1884109
08/03/15 08:39 AM
08/03/15 08:39 AM
The Netherlands
BigBlockMopar Offline
The Netherlands
I've got cars with engine oil in it some of them which is over 5-10 years old.
Not saying it's a good thing to do, but thinking of recycling still 'new' oil is the other extreme.
Re: Does engine oil have a shelf life? [Re: larrymopar360] #1884116
08/03/15 09:20 AM
08/03/15 09:20 AM
Port Huron, Michigan
MI_Custumz Offline
MI_Custumz  Offline
So how long is it good for once opened? Let's say for a lawnmower that doesn't quite take a quart of oil and you have some left in the container.
Re: Does engine oil have a shelf life? [Re: larrymopar360] #1884270
08/03/15 01:41 PM
08/03/15 01:41 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Your lawn mower is lot different than a 25K race motor, its all about the additives. The recommended test time for most oils is 4~5 years, if you have lots of it, then test it. What happens is the additives separate and the oil does not become effective in performing their jobs. In the airplane world, you get 4 years on a case, after that, junk it. People have been killed because someone got a deal on some old oil and was trying to save $50. When the additives go out of suspension, it wipes the bearings and galls other surfaces because it cant properly protect what need the lube. No you cant put in a can of STP and fix the problem. Some get lucky and are able to use it, others have not. To each their own. Tim
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Does engine oil have a shelf life? [Re: CompSyn] #1884399
08/03/15 04:15 PM
08/03/15 04:15 PM
Cincinnati, Ohio
Cincinnati, Ohio
Doug Hund
Shell Lubricants
Houston, TX 77002
doug.hund@shell.com
IMO the reason is to sell more oil.
Since when is water a problem? Oil and water don't mix. So what if a little water is in your oil. It will evaporate as soon as you start the engine and it get's hot. Water is a really weak argument IMO. I find many ounces of water under my valve covers on my aluminum racing engines, no big deal it evaporates in a hot motor.
I am in the oil business and used to retail motor oil, not so much now because there's no money in lubricants unless you sell alot of it, IMO.
Therefor I have 4 brands/grades of oil left over from the 90s. I have been using it up in recreational vehicles including my 2002 RV 505HP Cat diesel engine that see's extreme service.
I did a oil change over the weekend to my 71 440 6 pak. It's been at least 5 year since I have done a oil change to it because I didn't drive it much. I used this oil and drove the car 48 miles yesterday.
If your worried about the additives, shake it up first before you pour it in!! LOL
This bottle has 5-10-95 stamped right on the front of the bottle and it still protects I'm here to say from my experience with at least 4 kinds of oil and many different vehicles and pieces of equipment like generators and trenchers we use at work.
This what I put in my muscle car Saturday. I use 15 year old Shell Rotella in my Cat motor.
