Re: restoring a rusty car?
[Re: bigblockbryan]
#1881661
07/30/15 05:18 PM
07/30/15 05:18 PM
Posts: 7,073 fredericksburg,va
cudaman1969
fredericksburg,va
X-brace everything. Welded in, or you will never get it square- straight again. Your concrete floor is your plate. Drill and tamp in anchor-bolts on floor then build your brackets to align the car off these floor bolts. After making brackets, try to move car, if it moves, more cross bracing. I make story-poles(conduit pipe with pointed ends) to measure all reference points, you can forget measurements but that pole don't change.if you're off 1/8 here and 1/8 there nothing will line up properly again. So before anything is cut off look over the part carefully to se how to get new piece back to the same spot. If you cut it all off at the same time you better have a ton of jigs with alignments points off the car, wall, floor, pole anything stationary. The whole car is a structural member, remove any part and it will flex Good luck
[Re: ademon]
#1882143
07/31/15 11:19 AM
07/31/15 11:19 AM
DaytonaTurbo
Manitoba, Canada
Sounds like a lot of work for a car missing most of its parts. If you love doing that type of work go for it, I'm sure you know you won't get your money back on it. Agreed. You would be time and money ahead by buying one already done or at least a solid project. I know that sounds like a lot of money but add up what all that repro metal is worth, plus fabbing your rotisserie, jigs, not to mention your time, welding gas, wire, cutting wheels, etc.
[Re: bigblockbryan]
#1882309
07/31/15 03:15 PM
07/31/15 03:15 PM
Posts: 287 Greenville, N.C.
BarrsRestoration
Greenville, N.C.
Here is a link to a topic I started last year where I posted pictures of a Charger we did that was pretty rotted away. I also explained how I supported and braced it. I put on a roof, floors, wheel housings, rear body panel, quarters, doors, fenders, etc. Lots of fabrication needed for those pieces you just can't buy, or to make the pieces you can buy fit like they're supposed to. On this car the original hood, trunk lid and one rocker were retained. http://www.forbbodiesonly.com/moparforum/showthread.php?80425-Body-Building-101-1968-ChargerLots more pictures are posted here. www.barrsrestoration.com
[Re: bigblockbryan]
#1882473
07/31/15 08:12 PM
07/31/15 08:12 PM
Posts: 876 Illinois
StrkrDart69
Illinois
www.thepunctuationguide.com/This may help you if you need to punctuate a sentence and may help when people read your posts so they can read it and understand what you are saying and that way you may get more people to answer your question and then you might be able to get more responses to your question that may help you with your car. LOL just had to do it.
[Re: StrkrDart69]
#1882544
07/31/15 10:03 PM
07/31/15 10:03 PM
Posts: 1,223 Central Pa
moparjim79
Central Pa
