psi valve springs? #1882292
07/31/15 03:46 PM
07/31/15 03:46 PM
ky
68roadrunner Offline OP
ky
any users of psi valve springs. any good or bad comments welcome. thanks lee
Re: psi valve springs? [Re: 68roadrunner] #1882344
07/31/15 05:02 PM
07/31/15 05:02 PM
San Jose Ca.
boatracer572 Offline
San Jose Ca.
I've been using psi springs for a while now, with valve lifts over one inch on both intake and exhaust and more than eight thousand rpms I'm seeing 80 to 100 passes on a set...
Re: psi valve springs? [Re: 68roadrunner] #1882468
07/31/15 09:01 PM
07/31/15 09:01 PM
Menomonee Falls
DemonDust Offline
DemonDust  Offline
Menomonee Falls
I just changed a set that had over 3000 miles on them. They were pretty weak but car was still running under 10.0s
Two springs had the ends of the coil broken off. Other than that they had no other structural damage.
SDG Motorsports
Hellcat Demon and Redeye Supercharger CNC Porting
https://www.sdgmotorsports.com/
Re: psi valve springs? [Re: 68roadrunner] #1882779
08/01/15 11:27 AM
08/01/15 11:27 AM
ky
ky
thanks guys, looks like they are worth a try, and see if they hold up.
Re: psi valve springs? [Re: 68roadrunner] #1882784
08/01/15 11:39 AM
08/01/15 11:39 AM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Been using them for awhile and we have had very good luck with them.
Todd
