1959 chrysler new yorker wheels and brakes #1881487
07/30/15 01:43 PM
07/30/15 01:43 PM
alberta canada
tujo33 Offline OP
tujo33  Offline OP
alberta canada
Hello. I am planning on putting 15" rims with 255 60/15 on rear and 225/60/15 on the front of my 1959 new yorker. The clearance looks to be ok but everything is a special order and I'm wanting to be sure (no returns). Has anyone done this already so I can learn from their mistakes first?
Re: 1959 chrysler new yorker wheels and brakes [Re: tujo33] #1881760
07/30/15 09:30 PM
07/30/15 09:30 PM
moparx Offline
moparx  Offline
the tire sizes look to be no problem, but wheel width and back space will dictate if problems will arise. until those items are addressed, a definitive answer really can't be given. however, i am going to guess that if you use a factory 15 x 7 steel wheel on all corners, that "should" work.
beer
Re: 1959 chrysler new yorker wheels and brakes [Re: tujo33] #1881794
07/30/15 10:17 PM
07/30/15 10:17 PM
up yours
Supercuda Offline
About to go away
Supercuda  Offline
About to go away
up yours
I've never tried it on a 59 NY'er, but the stock 15x7 rims fit on things as esoteric as my 38 Plymouth to my 87 Diplomat, so I am guessing they should work fine here, but if you have anyone who can loan you a rim to test fit, go for it.
Don't be the exception.
