Re: Stagger IFR. Jetting ???
[Re: ademon]
#1881898
07/31/15 12:03 AM
07/31/15 12:03 AM
Posts: 12,099 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
I wouldn't stagger them like that.
How about this; since you are going to drill and tap them for screw-in bleeds anyway, why not drill the IFRs a bit bigger (say .001" or .002") and use the same wires? Or wire down your IABs. Either way should fatten up your idle a bit. And will give you a chance to see how it acts with each combo and if it likes one better than another. And I would concentrate on the center carb unless the outboard's idle circuits are way screwed up.
And have you checked your slot feed? By 1,500 your throttle plate position should be pulling on the slot a good bit.
Don't get too hung up on idle A/F ratio. Just give it what it likes whether that is in the 13s or the 14s. Get the mix screws in the 1 to 1 1/2 range with a solid idle and call it good. Then go to the slot for off idle and the air bleeds and emulsion holes for main circuit actuation timing.
On a side note, my old outboard carbs had idle mixture screws that were plugged over with lead. Any chance yours do too?
Master, again and still
[Re: ademon]
#1882117
07/31/15 11:52 AM
07/31/15 11:52 AM
Posts: 304 Florida
Mark Whitener
I find with 6-32 x 1/8 set screws you can run the tap in 4 to 4.5 turns and have the set screws thread in enough, without having the threads go thru to the idle well which you don't want.
Mark Whitener [url=www.racingfuelsystems.com[/url]
[Re: lockjaw-express]
#1883336
08/02/15 05:17 AM
08/02/15 05:17 AM
Posts: 6,906 IL, Aurora
ademon
IL, Aurora
What equipment are you using for measuring AFR?
Thanks, Mark Innovate MTX-L
