71 Charger R/T louver hood #1878970
07/27/15 10:14 AM
07/27/15 10:14 AM
bigbillfury Offline OP
Can someone please tell me what nuts I use for the 4 thin studs in the center of the louver? Are they anything specail? I already gave my you know what for the 12 bell nuts needed for the side. Thanks
Re: 71 Charger R/T louver hood [Re: bigbillfury] #1880786
07/29/15 02:48 PM
07/29/15 02:48 PM
Chilly Northern, Minn.
71 Charger R/T Offline
Yes, I'll try to attach a couple pictures…..
Hope this helps…
I think they are the same as the side marker lamp bezel nuts.
Re: 71 Charger R/T louver hood [Re: 71 Charger R/T] #1881241
07/30/15 12:00 AM
07/30/15 12:00 AM
Houston, Tx
hemi68charger Offline
Houston, Tx
Hope this helps…
Hey 71, do you need another clip for the drain hose/tube out the front? There should be 2...
Troy
Houston Mopar Connection Club
Re: 71 Charger R/T louver hood [Re: hemi68charger] #1881248
07/30/15 12:04 AM
07/30/15 12:04 AM
[/quote]
Hey 71, do you need another clip for the drain hose/tube out the front? There should be 2... [/quote]
Really? I wasn't aware of that! Yes, I guess I do! Do you have one?
Re: 71 Charger R/T louver hood [Re: bigbillfury] #1883296
08/02/15 02:20 AM
08/02/15 02:20 AM
SF Bay Area, CA
charger440sixpak Offline
SF Bay Area, CA
My insert has pal nuts on the center four posts and I believe they're original. Never seen acorn nuts on an insert before...
Re: 71 Charger R/T louver hood [Re: charger440sixpak] #1883414
08/02/15 11:12 AM
08/02/15 11:12 AM
Ontario, Canada
mccannix Offline
mccannix  Offline
Ontario, Canada
My untouched original had pal nuts as well, no acorn nuts.
Lousy picture but if you enlarge you can see them.
I dont have the hood anymore or I could take close-ups
Re: 71 Charger R/T louver hood [Re: mccannix] #1884486
08/03/15 06:01 PM
08/03/15 06:01 PM
Where can I find them? I will also need the hose and two clips as well.
