pro comp RTR dist? #1881097
07/29/15 09:46 PM
07/29/15 09:46 PM
scratchnfotraction Offline OP
I ordered one so I will see soon enough. BUT while I WAIT.
anyone run any of these?
anyone run the pro-comp HEI vac dist?
anyone run on of the GM HEI dist for the RB mopar engines?
seen a few at the swap meets and a few in some of the cars at shows but not sure how well they hold up.
55$ for a cast HEI or the GM/mopar HEI dist
the billet RTR dist for 75$
the cast housing HEI dist look to be the same thing as converting a stock dist over using a GM module and alum heat sink piece.
Re: pro comp RTR dist? [Re: scratchnfotraction] #1881104
07/29/15 09:50 PM
07/29/15 09:50 PM
wow! just watched counting cars and showed a 52 mercury with a mopar 440
it has one of the pro-comp vac dist in it. backed it up a couple time to pause it and sure nuff. just like the ones I see at the local swap meet for 100$
Re: pro comp RTR dist? [Re: scratchnfotraction] #1881141
07/29/15 10:25 PM
07/29/15 10:25 PM
here they are.
Re: pro comp RTR dist? [Re: scratchnfotraction] #1881143
07/29/15 10:28 PM
07/29/15 10:28 PM
the module is 14$ if it goes out. and a dist only cost 55$
the GM HEI mopar dist looks like it is as easy to curve as a chebby or MSD
Re: pro comp RTR dist? [Re: scratchnfotraction] #1881148
07/29/15 10:32 PM
07/29/15 10:32 PM
Granite Bay CA
Kern Dog Offline
Striving for excellence
Kern Dog  Offline
Granite Bay CA
When I see HEI I get visions of a distributor cap only slightly smaller than the platter Mom used to serve the turkey. Good to see they made it a wee bit more compact!
Rick Ehrenberg says that the MP distributors made by Mallory are very prone to spark scatter. While I sorta understand this, I am sure there are thousands of guys running MP distributors that seem to be pleased with them. I don't know what effect that has, maybe on a higher HP build it becomes an issue?
Anyway, that HEI looks nice. luck
Re: pro comp RTR dist? [Re: Kern Dog] #1881158
07/29/15 10:43 PM
07/29/15 10:43 PM
I know the GM cap with coil is huge looking but 34$ will replace all of it with a new coil if it fails. unlike some of the others on the market.
I do not care for the chebby look of the cap but sure know I never had trouble with a stock GM HEI dist in the mud trucks.
they would run under water till it suck it down the carb.
and talk about bang your head on the hood when it would shock you finding the bad plug wire by hand.
looks tall enough it will clear my stock heads and VC.
when I hear HEI, I think of the large cap/coil or the module itself. which I think why the small mopar dist is called a HEI due to the GM module being used.
Re: pro comp RTR dist? [Re: scratchnfotraction] #1881216
07/29/15 11:32 PM
07/29/15 11:32 PM
colorado
68charger440strk Offline
colorado
I have one, and burned out the module twice. Then I went to an MSD setup. In all fairness, I was also having some electrical problems at the same time, so it may have been that causing the modules to burn out. In either case tbe MSD did not burn out even though I still had the other electrical problems. Now my elec stuff is all fixed but I dont want to switch back.
Re: pro comp RTR dist? [Re: 68charger440strk] #1881235
07/29/15 11:54 PM
07/29/15 11:54 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Our experiences with pro comp HEI (GM) distributors is REPLACE THE MODULE before it leaves the shop. Doesn't matter whether its a new install or the car came in with one for other issues. Change the MODULE.
Otherwise no issues. twocents
Re: pro comp RTR dist? [Re: scratchnfotraction] #1881277
07/30/15 01:04 AM
07/30/15 01:04 AM
what module do you replace it with?
Mallory?
Re: pro comp RTR dist? [Re: scratchnfotraction] #1881362
07/30/15 08:46 AM
07/30/15 08:46 AM
bump for the day crew...anyone else?
Re: pro comp RTR dist? [Re: scratchnfotraction] #1881432
07/30/15 11:51 AM
07/30/15 11:51 AM
anyone else want to chime in?
thanks for the opinions so far.
