restoring a rusty car? #1881015
07/29/15 08:02 PM
07/29/15 08:02 PM
United states wisconsin
bigblockbryan Offline OP
okay i have a 1970 dodge charger anyway its super rusty i parted it out once long ago.
Now i have heard people say you should put car in a jig if you have not much to weld to the car sure will need both qarter panels tail panel trunk rear frame rails the roof deck filler is good. I believe the the floors are saveable but i would like to put new full floor in also my thinking about fixing this car is it will cost alot im also toying with the idea of building rotisorie to put it on or would a jig be better and does anyone know if they sell jigs for such a thing or have a picture of one so i could build one
Re: restoring a rusty car? [Re: bigblockbryan] #1881056
07/29/15 08:56 PM
07/29/15 08:56 PM
IL, Aurora
ademon Offline
ademon  Offline
IL, Aurora
Sounds like a lot of work for a car missing most of its parts. If you love doing that type of work go for it, I'm sure you know you won't get your money back on it.
Re: restoring a rusty car? [Re: ademon] #1881077
07/29/15 09:32 PM
07/29/15 09:32 PM
Figured I post a pic
Re: restoring a rusty car? [Re: bigblockbryan] #1881163
07/29/15 10:48 PM
07/29/15 10:48 PM
MN
58pwrwgn Offline
58pwrwgn  Offline
MN
I'm doing the same with a 69. Go to dodgecharger.com . Lots of guys doing the samething on cars probably rustier than yours, you would be amazed. I put mine on jack stands. I used the head unit from a survey transit mounted on the floor to check the height side to side.
I dropped a plumb to the floor so I could measure an x pattern at several spots to see that it was square. There are some frame diagrams ask someone to post them
Re: restoring a rusty car? [Re: bigblockbryan] #1881661
07/30/15 06:18 PM
07/30/15 06:18 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
X-brace everything. Welded in, or you will never get it square- straight again. Your concrete floor is your plate. Drill and tamp in anchor-bolts on floor then build your brackets to align the car off these floor bolts. After making brackets, try to move car, if it moves, more cross bracing. I make story-poles(conduit pipe with pointed ends) to measure all reference points, you can forget measurements but that pole don't change.if you're off 1/8 here and 1/8 there nothing will line up properly again. So before anything is cut off look over the part carefully to se how to get new piece back to the same spot. If you cut it all off at the same time you better have a ton of jigs with alignments points off the car, wall, floor, pole anything stationary. The whole car is a structural member, remove any part and it will flex Good luck
Re: restoring a rusty car? [Re: ademon] #1882143
07/31/15 12:19 PM
07/31/15 12:19 PM
Manitoba, Canada
DaytonaTurbo Offline
Manitoba, Canada
Agreed. You would be time and money ahead by buying one already done or at least a solid project. I know that sounds like a lot of money but add up what all that repro metal is worth, plus fabbing your rotisserie, jigs, not to mention your time, welding gas, wire, cutting wheels, etc.
Re: restoring a rusty car? [Re: bigblockbryan] #1882309
07/31/15 04:15 PM
07/31/15 04:15 PM
Greenville, N.C.
BarrsRestoration Offline
Greenville, N.C.
Here is a link to a topic I started last year where I posted pictures of a Charger we did that was pretty rotted away. I also explained how I supported and braced it.
I put on a roof, floors, wheel housings, rear body panel, quarters, doors, fenders, etc. Lots of fabrication needed for those pieces you just can't buy, or to make the pieces you can buy fit like they're supposed to.
On this car the original hood, trunk lid and one rocker were retained.
http://www.forbbodiesonly.com/moparforum/showthread.php?80425-Body-Building-101-1968-Charger
Lots more pictures are posted here.
www.barrsrestoration.com
Re: restoring a rusty car? [Re: bigblockbryan] #1882473
07/31/15 09:12 PM
07/31/15 09:12 PM
Illinois
StrkrDart69 Offline
StrkrDart69  Offline
Illinois
www.thepunctuationguide.com/
This may help you if you need to punctuate a sentence and may help when people read your posts so they can read it and understand what you are saying and that way you may get more people to answer your question and then you might be able to get more responses to your question that may help you with your car.
LOL just had to do it.
Re: restoring a rusty car? [Re: bigblockbryan] #1882527
07/31/15 10:37 PM
07/31/15 10:37 PM
Brookville Pa
crowbait Offline
crowbait  Offline
Brookville Pa
pics Bryan?
Re: restoring a rusty car? [Re: StrkrDart69] #1882544
07/31/15 11:03 PM
07/31/15 11:03 PM
Central Pa
moparjim79 Offline
moparjim79  Offline
Central Pa
