Bumper Diff?71-72 charger
#1880741
07/29/15 02:02 PM
07/29/15 02:02 PM
Posts: 244 York,NE
WOTcuda
York,NE
Is The 71 Charger Bumper,Rear Different than 72 - Cant Find Repro. For 72
Re: Bumper Diff?71-72 charger
[Re: roadhazard]
#1880948
07/29/15 06:18 PM
07/29/15 06:18 PM
Posts: 553 DE
Ply72rr
DE
From what I understand they are the same other than the slots for the jack hook. I'm sure someone more knowledgeable than I can confirm or debunk. Correct, 72 has slots for bumper jack, 71 jacks used a hook that grabbed the bottom of the bumper.
[Re: Ply72rr]
#1880963
07/29/15 06:49 PM
07/29/15 06:49 PM
Posts: 489 Chilly Northern, Minn.
71 Charger R/T
From what I understand they are the same other than the slots for the jack hook. I'm sure someone more knowledgeable than I can confirm or debunk. Correct, 72 has slots for bumper jack, 71 jacks used a hook that grabbed the bottom of the bumper. I second that! They are a bolt-up but the '72 has the slots.
[Re: WOTcuda]
#1880966
07/29/15 06:55 PM
07/29/15 06:55 PM
Posts: 2,356 Kentucky
dfsmopars
Kentucky
Embarrassed to say I have a '72 and never paid attention to that. I even swapped in '71 r/t tail lights for the plain '72s.
‘72 Charger, 5.9 Magnum, Tremec 5 spd., Pro-Touring ‘14 Big Horn, Quad Cab, 4x4, 1500
[Re: WOTcuda]
#1880994
07/29/15 07:31 PM
07/29/15 07:31 PM
71 Charger R/T
Tail light Housing Interchangable ? No! The standard housings from '71 to '72 are not interchangeable. The Rallye,R/T and 500 lights, however, are the same. If you were asking if the housings for either year will fit the bumper………. Yes. they have the same mounting tab locations for the taillamp housings.
[Re: WOTcuda]
#1881033
07/29/15 08:30 PM
07/29/15 08:30 PM
dfsmopars
Kentucky
Then they must work if you Swapped '71 r/t to plain '72 Swapped them out slick as a gut with no modifying.
