Re: Shopping for race trailer [Re: RTSE4ME] #1881606
07/30/15 04:42 PM
07/30/15 04:42 PM
Stuttgart, Arkansas
rickseeman Online content
rickseeman  Online Content
Stuttgart, Arkansas
I bought a 26' MTI aluminum trailer. It was $9,950 before options. Dirt cheap for an aluminum trailer. Normal quality level. It was over $20,000 with all the options but don't buy a stripper. Get every option you want so you will be happy with it. Get every cabinet, you will need them. They got me the financing.
2011 Drag Pak Challenger
Re: Shopping for race trailer [Re: RTSE4ME] #1881734
07/30/15 08:55 PM
07/30/15 08:55 PM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Originally Posted By RTSE4ME
I will have to see if the bigger axles are available on the model I am looking at. Dealer told me that not all options are available.
Also, we are already at the top end of the budget with a new ATC. I guess I would rather have a higher end bare bones trailer vs a lower end with a ton of options.
Don't cut corners on the axles and tires, 16" wheels and heavier axles should be mandatory, even if it's aluminum.
22' foot would be a mistake, you should get a 26 like the guys above are telling you. I have had 4 enclosed trailers. twocents Good luck.
Re: Shopping for race trailer [Re: Challenger 1] #1882102
07/31/15 11:34 AM
07/31/15 11:34 AM
Mesa, Arizona
dart4forte Offline
dart4forte  Offline
Mesa, Arizona
I just got finished going through the suspension on mine. Bottom line these trailer manufacturers build these trailers as cheaply as they can. I had a shackle fold up on me and found that all the shackles had been essentially tack welded. Also found they used plastic bushings. When I first got my trailer I was wearing out tires especially the right rear. Took it to a shop where they found the axles out of alignment. When you buy one insist on getting the dealer to do an alignment. I'd also have them install new bushings with greasable bolts.
Abe Lincoln
Re: Shopping for race trailer [Re: RTSE4ME] #1884373
08/03/15 03:41 PM
08/03/15 03:41 PM
Washington DC via parts unknow...
chubbywiggins Offline
Pro-line Trailers down in Virginia sells high end trailers as well. I bought one of the basic models like this one last year. http://www.prolinetrailersales.com/specials/8-5x24-enclosed-trailer-ii
While I was there, the salesperson took time to show me around, they had Vintage, Haulmark, and Loaded up Pro-line 28's. Be sure to let them know the options, they can fit about any budget. www.prolinetrailersales.com
