0-20 lb tire pressure gauge #1880604
07/29/15 11:12 AM
07/29/15 11:12 AM
Houston, Texas
TheOtherDodge Offline OP
Houston, Texas
I have a 0-15 lb Moroso but with my drag radials I need something that goes to 20 lbs. Any suggestions on which is the best?
Thanks!
Re: 0-20 lb tire pressure gauge [Re: TheOtherDodge] #1880613
07/29/15 11:15 AM
07/29/15 11:15 AM
Cincinnati, Ohio
Challenger 1 Offline
Cincinnati, Ohio
Thanks!
Replace the gauge with a 0-30# gauge, use the same hose and air chuck.
Link
Re: 0-20 lb tire pressure gauge [Re: Challenger 1] #1880617
07/29/15 11:23 AM
07/29/15 11:23 AM
Cincinnati, Ohio
Cincinnati, Ohio
I removed my hose and air chuck, added a longer fuel hose to my air gauge and used it to check my fuel pressure while driving. The moroso 0-15 psi gauge was perfect for that. It's back to a air gauge now.
Re: 0-20 lb tire pressure gauge [Re: TheOtherDodge] #1880622
07/29/15 11:32 AM
07/29/15 11:32 AM
Az
Crizila Offline
Crizila  Offline
Az
Think Jegs is running a sale on air gauges right now - 15, 30, 60 lb gauges. They look pretty good.
Fastest 300
Re: 0-20 lb tire pressure gauge [Re: TheOtherDodge] #1880629
07/29/15 11:41 AM
07/29/15 11:41 AM
Houston, Texas
Houston, Texas
I really don't want one that goes to 30 lbs as I will never go past 20. The smaller the greatest reading will allow for more in between increments.
I can't use my current gauge for fuel pressure because I run FI on everything I own.
Re: 0-20 lb tire pressure gauge [Re: TheOtherDodge] #1880632
07/29/15 11:45 AM
07/29/15 11:45 AM
Cincinnati, Ohio
Cincinnati, Ohio
A 0-30# will be the most accurate for you. Always want your readings in the middle of the scale.
BTW the CSI one is the most expensive air gauge that I know about, you asked what was best.
Re: 0-20 lb tire pressure gauge [Re: TheOtherDodge] #1880649
07/29/15 12:07 PM
07/29/15 12:07 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We bought a couple of these. They work very well and match my high dollar Longacre and Moroso gauges. They have increments of .1 lbs
http://www.ebay.com/itm/151697783180?_trksid=p2060353.m2749.l2649&ssPageName=STRK%3AMEBIDX%3AIT
Re: 0-20 lb tire pressure gauge [Re: TheOtherDodge] #1880745
07/29/15 02:09 PM
07/29/15 02:09 PM
Houston, Texas
Houston, Texas
Thanks guys! Al, I like the digital gauge, especially because it is pretty inexpensive and you stated it matches your high dollar ones!
Re: 0-20 lb tire pressure gauge [Re: TheOtherDodge] #1880749
07/29/15 02:17 PM
07/29/15 02:17 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I was surprised myself. We were just looking for something to do front tires, golf cart, trailer etc. We put one in the dragsters toolbox to take to the lanes now. Will stick with my uber dollar one for the Stratus for now for appearances sake smile
Re: 0-20 lb tire pressure gauge [Re: TheOtherDodge] #1881057
07/29/15 08:59 PM
07/29/15 08:59 PM
Texas
GoodysGotaCuda Offline
5.7L Hemi, 6spd
5.7L Hemi, 6spd
Texas
Cheap, but it works for me. I think I found it at Bass Pro in their ATV section.
http://slime.com/535/products/1-20-psi-low-pressure-gauge-20185/
1972 Barracuda - 5.7L Hemi, T56 Magnum 6spd - https://www.facebook.com/GoodysGotaHemi
2020 RAM 1500
[img]https://i.imgur.com/v9yezP9.jpg[/img]
Re: 0-20 lb tire pressure gauge [Re: TheOtherDodge] #1881111
07/29/15 09:52 PM
07/29/15 09:52 PM
Wind Gap,Pa.
Sammy Offline
Sammy  Offline
Wind Gap,Pa.
Slimes digital gauge matched my Longacre and Moroso digital gauge exactly for $9.99
Re: 0-20 lb tire pressure gauge [Re: TheOtherDodge] #1881120
07/29/15 10:00 PM
07/29/15 10:00 PM
Val-haul-ass... eventually
BradH Offline
BradH  Offline
I bought one of these from Jeg's: http://www.jegs.com/i/JEGS-Performance-P...702#moreDetails
Cross-checked it against my Moroso 0-15 at 15 psi and it was almost identical; cross-checked it against another gauge of mine I've had for years at 45 psi and it was w/in 1/2 psi. It's my go-to gauge now for everything except needing to air up the space-savers at 60 psi.
