Re: "Custom 33"
[Re: dogdays]
#1922531
09/30/15 02:38 PM
09/30/15 02:38 PM
Posts: 7,506 Az
Crizila
Az
Please remind me how to apply POR-15. Spray or brush? Or how?
Thanks, R. I think you can go both ways, but I brushed my stuff. Lays down well if you use a fine brush. Did the calipers with their caliper paint to handle the heat. Por 15 satin color matched the powder coat satin real close. Did the exhaust system in black satin ceramic coating, which matched the other coatings also. It will be pretty boring under there, but it should hold up will when I am off roading.
Fastest 300
Re: "Custom 33"
[Re: moparx]
#1923219
10/01/15 11:23 AM
10/01/15 11:23 AM
Posts: 7,506 Az
Crizila
Az
Thanks for the hitch input. Had to drop the receiver down that far to clear the rear roll pan. Yes, 1/4" plate for mount. Empty trailer weight ( fiberglass box on a simple square frame ) is approx. 350 lbs ( tires and all ). Can't see it over 1000 lbs. gross. For and aft won't be a problem, but might consider "boxing in" the down section to address your twisting concerns. Thanks again for the input.
Fastest 300
Re: "Custom 33"
[Re: dogdays]
#1924317
10/02/15 05:02 PM
10/02/15 05:02 PM
Posts: 7,506 Az
Crizila
Az
Re: trailer hitch
1. Needs to be boxed for sideways loads. Even pulling the trailer around a curve will cause it to deflect sideways and probably twist.
2. Rear crossmember appears to be a C-channel, which is very weak in torsion. Meaning the trailer hitch is going to cause it to twist. I'd suggest boxing it for at least 3/4 of the total length, boxing centered in the middle. In other words you could leave 6" or so open on each side to allow wiring, etc to be run inside the box. The box doesn't need to be real thick, but 3/16" would be good is my SWAG.
It all looks so clean, makes me wish for a garage.....
R. 10-4 on #1. Rear cross member is 3/16" square tubing. Same as rest of frame. No problem there. Body will be coming back off in 2-3 weeks for paint. I will box in the hitch mount then. Appreciate the input from everyone. It's one reason why I post pictures.
Fastest 300
Re: "Custom 33"
[Re: Crizila]
#1933622
10/17/15 12:21 AM
10/17/15 12:21 AM
Posts: 7,506 Az
Crizila
Az
After a little over 1 year of work, it went off to paint and interior today.
Fastest 300
Re: "Custom 33"
[Re: moparx]
#1946827
11/07/15 10:31 AM
11/07/15 10:31 AM
Posts: 7,506 Az
Crizila
Az
Thanks Moparx! Ya, shootin for about mid summer to get it on the road - if all works out.
Fastest 300
Re: "Custom 33"
[Re: Crizila]
#1958412
11/26/15 03:14 PM
11/26/15 03:14 PM
Posts: 7,506 Az
Crizila
Az
Getting closer. Body is in paint and interior is coming together.
Fastest 300
Re: "Custom 33"
[Re: moparx]
#1958783
11/27/15 01:32 PM
11/27/15 01:32 PM
Posts: 7,506 Az
Crizila
Az
Thanks, it's a Dodge truck color - Western brown pearl.
Fastest 300
