Re: Which manual valve body for 727?
[Re: MOPARCRAZY]
#1873971
07/19/15 11:51 PM
07/19/15 11:51 PM
Posts: 3,378 Rancho Cordova, CA
Exit1965
Rancho Cordova, CA
oops! below is forward pattern, didn't see you wanted RVMB.
Turbo Action 17875XA
17875XA: CHEETAH XtremeAction Pro Street and Race Manual (PRN321) The 17875XA has a safe clean neutral and no need to use a button to backup. A clean rear band apply and release making it a great race or street valve body and No roller clutch failure. Provides full manual control only. No automatic features. Maintains stock shift pattern. Allows full engine braking (slow down) of vehicle by down shifting. This valve body is great for Drag Racing, Rock Crawling, Mud Bogging, Sports Car Racing and Pro Street. Eliminates use of passing gear linkage.
[Re: DusterW2]
#1874169
07/20/15 10:54 AM
07/20/15 10:54 AM
Posts: 1,305 Lakewood, Colorado
herkamer
Lakewood, Colorado
Griner Engineering
model # 1222G05B RMVB low band apply, high pressure 727specialist is a distributor
FYI, out of stock with no foreseeable date in the future. I just talked to Keith on Friday about it.
Matt 69 Dart Swinger 340 83 W350, Megasquirted with 46RH Old news: 72 Demon street/race mobile Latest: 70 Duster backhalf car and even more
[Re: Exit1965]
#1875755
07/22/15 02:09 PM
07/22/15 02:09 PM
Posts: 1,751 Graham, WA
Polarapete
Graham, WA
Years ago I used the Cheetah RMVB #17156, but I now like the idea of a forward pattern so that I could pop the trans into neutral at the end of the run and coast down (we have lots of shut down room where I will be racing again). Theoretically, that will save an engine, but I have yet to see it proven.
1986 Dodge Ramcharger 440 2wd, Bracket Racer Under Construction 1998 Ram 2500 QuadCab, new daily driver. 2008 Honda Element 2014 Carry-On 7x14 Cargo Trailer
[Re: Exit1965]
#1875949
07/22/15 06:17 PM
07/22/15 06:17 PM
Posts: 6,531 Jacksonville, FL
Chris2581
Jacksonville, FL
This is what I'd use. Turbo Action makes very good products.
[Re: MOPARCRAZY]
#1876089
07/22/15 09:33 PM
07/22/15 09:33 PM
Posts: 3,696 jersey
Spaceman Spiff
jersey
i went with a Cope RMVB. But i have a '65 Cable shift trans in my car, so i can keep the push buttons.
526 cubes of angry wedge, pushbutton shifted, 9 passenger killer!
[Re: Spaceman Spiff]
#1876120
07/22/15 10:20 PM
07/22/15 10:20 PM
Posts: 1,675 Mi.
G-Money1320
Mi.
So will a FMVB non LBA valve body wear out a trans faster? I have one in my street car that sees occasional track duty.
416 stroker from Nick at Compu-flow. 11.14 in full street trim. Seems like a new best every time out. 11.06 open headers----so far!!
