Re: What is the difference between an 8896 and 9375? [Re: Thumperdart] #187207
01/08/09 01:19 PM
01/08/09 01:19 PM
Riverside, Ca
G_bob Offline OP
G_bob  Offline OP
Riverside, Ca
Gotcha.... I also believe another difference is that the new dommys have a flat venturi area on top where the old ones had that lip/raised ring around the boosters.
I've noticed that.
The whole -1, -2, -3 had me totally confused, as I can only find -1 listed as part number on the internet, Holley site, Summit site, etc. Example, 0-8896-1. There is no -2 listed anywhere that I could find.
Re: What is the difference between an 8896 and 9375? [Re: G_bob] #187208
01/08/09 01:37 PM
01/08/09 01:37 PM
Diego-Town, CA
Diego_Ted Offline
Diego_Ted  Offline
Diego-Town, CA
Glenn, is it more cost effective to buy a Carb from Summit and then have it worked by a guru or to just buy a worked carb from the Guru in the first place?
Re: What is the difference between an 8896 and 9375? [Re: G_bob] #187209
01/08/09 01:37 PM
01/08/09 01:37 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
I bought my carb several years ago so who knows what they`ve changed.
Re: What is the difference between an 8896 and 9375? [Re: Diego_Ted] #187210
01/08/09 01:44 PM
01/08/09 01:44 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
I suggest you buy the "Ultra" Dominator, part number 80672 for 1050 or 80673 for 1150. These are Holleys answer to "trick" carbs. They have billet metering blocks with interchangeable emulsion jets and idle feed restrictions. The large sight window bowls, adjustable air bleeds and all the other tricks you would send your carb out to have performed on it.
Monte
Re: What is the difference between an 8896 and 9375? [Re: Monte_Smith] #187211
01/08/09 03:16 PM
01/08/09 03:16 PM
AndyF Offline
AndyF  Offline
I have the 80672 and it is a great carb. Pig rich on the intermediate circuit out of the box but the nice thing about the Ultra series carbs is that you can replace the fuel circuit jets in just a few minutes and then it is dialed in. I had to drop the intermediate fuel jets about 20 sizes from stock on my carb and then it started to make some serious power on the dyno. Idle and main circuits were spot on right out of the box. Very nice carb and quite a bit lighter since it has the aluminum baseplate and aluminum metering blocks. (I did an article for Mopar Muscle on that carb and its little brother, the 950 UltraHP)
The only serious issue I know of with that carb is that on really powerful motors there might not be enough main well capacity to keep the AF ratio happy at high speed. Some engine builders say that they can't jet them big enough to keep the fuel curve flat on the top end. I'm not sure if that is the truth or a fairy tale but I do know that BLP sells a metering block where they divorce the idle tube from the main well just to solve that issue.
Re: What is the difference between an 8896 and 9375? [Re: Monte_Smith] #187212
01/08/09 03:36 PM
01/08/09 03:36 PM
Cab_Burge Online work
Cab_Burge  Online Work
Monte, I went out and looked at my three 1050 Dominators that I have now, two 9375 early versions and the one newer 9375-2 which is the one that I thought had the HP cast into the drivers side, it does not have that. I learned something from you on that I remember Summits site advertising the new "Holleys HP series" Dominators with improved throttle repsonce and so on so maybe that is where I got the HP reference on the newer Dominators. I should check my three 4150 HP series carbs to see if they have the HP cast onto the sides of them I was under the impressiion that Holley had revised the Dominators to become the HP sereis Dominators back 8 to 10 yrs. ago to compete with BG King series carbs and the other after market carb. companys like Quik Fuel, Pro Form and so on and custom carb makers and modifiers like the "Carb Shop, Chuck Nuygtten(SP?) and the others out there. I wasn't aware that Holley had discontinued the newer "HP" type Domiator line and replaced it with the 'Ultra" series line, thanks for that information Some times I "assume" things from readings adds and public inforamtion (marketing) releases in the Dragster and need straight information from someone at the source like your self I hope that I have not misled or provided any misinformation to anyone on this forum that has led to confusion on there parts, if so I'm sorry Now back to work on more projects that are productive like showing the physcical differences from the top view of the early and later non Ultra 9375 carbs, the one that I had thought was the HP type is the three circiut one on the left, you can see the removable bleeds on the top versus the earlier one with two circiuts and non removable bleeds, which is the one that I like the best for a foot brake car
Re: What is the difference between an 8896 and 9375? [Re: Cab_Burge] #187213
01/08/09 04:48 PM
01/08/09 04:48 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
My 1050 8082-3 CLEARLY has an hp embosed on the metering blocks for what it`s worth.
Re: What is the difference between an 8896 and 9375? [Re: AndyF] #187214
01/08/09 05:33 PM
01/08/09 05:33 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
Andy, I ran the 1150 Ultra on a 632 Chevey recently. The motor made 1154hp with a well known "trick" carb on it and 1166hp with an OOTB 1150 Ultra on it. The fuel curve was great, but as you say, it was a touch lean up top. A couple jet changes cleared it right up. Motor made no more peak, but average was better. This motor really needed a 1250, but at this time, the new 1250 Ultra is not ready for release.
Monte
Re: What is the difference between an 8896 and 9375? [Re: Thumperdart] #187215
01/08/09 05:36 PM
01/08/09 05:36 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
When they went to screw in bleeds, the castings were changed, as shown in Cabs post. An early casting of the revised carbs, may or may not have HP cast into it. I have 6 Dominators here of various sizes, but all have screw in bleeds. Some say HP, some don't.
Monte
Re: What is the difference between an 8896 and 9375? [Re: Monte_Smith] #187216
01/08/09 05:41 PM
01/08/09 05:41 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Thankxx Monte, all good info here.
Re: What is the difference between an 8896 and 9375? [Re: Thumperdart] #187217
01/08/09 08:37 PM
01/08/09 08:37 PM
i'm not sure if you guys saw it earlier this week, but we're having a sale on Holley Carbs. that 80672 ultra dominator is just one of many we have ready to go.
that's a real sweet carb and the price is right too...
Post deleted by Defbob #187218
01/08/09 09:11 PM
01/08/09 09:11 PM
Re: What is the difference between an 8896 and 9375? #187219
01/08/09 09:37 PM
01/08/09 09:37 PM
Wisconsin
BIGS Offline
BIGS  Offline
Wisconsin
Great info here.......
Jesse & Lynn BIGS Performance Products Building Street/Strip Carburetors since 1974 www.bigsperformance.com
Re: What is the difference between an 8896 and 9375? [Re: BIGS] #187220
01/08/09 11:16 PM
01/08/09 11:16 PM
Keysville, VA
drag440 Offline
mopar addict
drag440  Offline
mopar addict
Keysville, VA
Got a few new wrinkles on my brain too
Re: What is the difference between an 8896 and 9375? [Re: drag440] #187221
01/08/09 11:32 PM
01/08/09 11:32 PM
State of Corruption
camdog440 Offline
camdog440  Offline
State of Corruption
What about Dominators from some of the specialty shops like the old Bill Mitchell Hardcore carbs? Were they any different from a Holley version?
Re: What is the difference between an 8896 and 9375? [Re: camdog440] #187222
01/09/09 01:48 PM
01/09/09 01:48 PM
There are a bunch of different Holley Dominators from Holley, all the aftermarket shops buy there parts from Holley and make there own versions to sell, so I would say yeah, there is a bunch of differences in custom made Dominators. I have own one bad aftermarket custom made expensive one so far
Re: What is the difference between an 8896 and 9375? [Re: Monte_Smith] #187223
01/09/09 02:03 PM
01/09/09 02:03 PM
State of confusion
Thumperdart Offline
Thumperdart  Offline
State of confusion
Monte....aren`t the newer style dommys .250 taller also? I thaught I read that when I bought mine.............
Stinnett Racing [Re: Thumperdart] #187224
01/09/09 02:09 PM
01/09/09 02:09 PM
Dyno1 Offline
Dyno1  Offline
call Gary Stinnett, he is an expert on the Holley carbs, he does many for NHRA racers. 620-343-1713, tell him Dyno told you to call.
Re: What is the difference between an 8896 and 9375? [Re: AndyF] #187225
01/10/09 12:12 AM
01/10/09 12:12 AM
Milwaukee
ToddP Offline
super street
ToddP  Offline
super street
Milwaukee
I am running a 80672 as well in a 540.
A nice feature is that all jets can be replaced via some form of screw in jet.
Holley in my opinon really missed the mark on the out of box set up on this carb.
Also the design of the metering block that feeds the idle well from the main well is of poor design. Bo laws divorced metering block is probably the best solution , but why on a $1000 supposed trick, out of the box carb.
Most important is the over emulsification of the main well. they use (3) .026" emulsion jets,( look at a 4779 metering block, it uses only (2) emulsion bleeds, and is probably one of the best out of the box Holley carbs ever sold.) a .026" kill bleed and a .031" hsab.
The problem with this is the fuel curve leans out on the top end. Too much emulsion jet.( for large cid engines)
a .026" hsab really helps out the fuel curve.
I have disabled the intermediate circuit as it was extremely rich. and with the over emulsified main well the high speed circuit transitions very quickly from the transition slot to the annular boosters, making an intermediate circuit unnecessary.
WARNING!
Dont even try an ultra dominator without a wide band o2 guage.
Re: What is the difference between an 8896 and 9375? [Re: ToddP] #187226
01/10/09 12:34 AM
01/10/09 12:34 AM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
in general terms, i refer to the newer and older 4500 series carbs as:
right- "the early style"
left- "hp style"
with regards to G-Bobs original question, i'd get the 8896 myself.
