70 440 six pack 4sp distributor vacuum advance ???? #1869504
07/13/15 05:10 PM
07/13/15 05:10 PM
Oakville.ON,Canada
hemi_rtdave Offline OP
Oakville.ON,Canada
I see two part numbers listed for the distributor! One early , one late.
I'm trying to figure out if i need the regular vacuum advance or the electronic vacuum advance?
Car was sced for build Feb 14 of '70
Re: 70 440 six pack 4sp distributor vacuum advance ???? [Re: hemi_rtdave] #1869621
07/13/15 08:16 PM
07/13/15 08:16 PM
USA
b54406barrel Offline
USA
Don't have the numbers (??19, maybe?) but my old '70 rr dist. was plain old vacuum can/dual point. Build date date was 07/24/70, LA car.
old dist pic
Re: 70 440 six pack 4sp distributor vacuum advance ???? [Re: b54406barrel] #1869660
07/13/15 09:12 PM
07/13/15 09:12 PM
Florida, US
72ls5fla Offline
72ls5fla  Offline
Florida, US
my car was built 6/13/70 and has a regular advance can with DP distributor.
nothing electronic.
maybe smog related engines got that.
or it had to do with engine options and configurations... ???
don't know....
bill
Got me a NEW Project
1970 GTX 440+6, 4 spd, 4.10 Dana and N96 FE5 (top/bottom) and black bucket interior.
Original transmission and Dana - Engine is a service replacement block.
Body has all stamped #s + VIN/TRIM tag and door sticker. Been hunting like all hell to find the Build Sheet.
garage find, only had 41,850 miles on ODO.
Re: 70 440 six pack 4sp distributor vacuum advance ???? [Re: 72ls5fla] #1869685
07/13/15 09:29 PM
07/13/15 09:29 PM
Oakville.ON,Canada
Oakville.ON,Canada
Anyone else !! This is very helpfull!!
Re: 70 440 six pack 4sp distributor vacuum advance ???? [Re: hemi_rtdave] #1869713
07/13/15 09:53 PM
07/13/15 09:53 PM
Blair County,PA
62maxwgn Offline
62maxwgn  Offline
Blair County,PA
My Superbird,Prestolite dual point.# 3439314 dated 41 9
Re: 70 440 six pack 4sp distributor vacuum advance ???? [Re: hemi_rtdave] #1869792
07/13/15 10:42 PM
07/13/15 10:42 PM
California
1970mopar Offline
1970mopar  Offline
California
I believe you will find that the "electrical" assisted vacuum advance was introduced sometime around January 1970 and was related to the N95 option code (california emissions)
Re: 70 440 six pack 4sp distributor vacuum advance ???? [Re: 1970mopar] #1869803
07/13/15 11:03 PM
07/13/15 11:03 PM
USA
USA
Mine was n95, no electrics. shruggy
Re: 70 440 six pack 4sp distributor vacuum advance ???? [Re: 1970mopar] #1869877
07/14/15 12:36 AM
07/14/15 12:36 AM
Philadelphia PA
Pynzo Offline
Drugs are bad
Pynzo  Offline
Drugs are bad
Philadelphia PA
I recall it was not an assist, but rather a retard for the timing at idle. Check your FSM. AVS carbs had a ground at the idle screw. 6 Packs did not.
Re: 70 440 six pack 4sp distributor vacuum advance ???? [Re: hemi_rtdave] #1870052
07/14/15 12:20 PM
07/14/15 12:20 PM
California
biggE Offline
biggE  Offline
California
Defiantly the later type vacuum advance. I believe PN 3420919. I believe the arm should have 11 stamped on it.
