Re: Degree wheels, and openings
[Re: DemonDust]
#1868782
07/12/15 02:18 PM
07/12/15 02:18 PM
Posts: 580 Livermore, CA
Dduster
Livermore, CA
Got in a hurry, but continue to check on www.jegs. com, www.compcams.com and www.moroso.com too. The information is out there, YOu just have to look for It. I was window shopping for a new degree wheel and learned about the range adapters that come with I think Compcams and perhaps Jegs as well.
[Re: DemonDust]
#1868795
07/12/15 02:35 PM
07/12/15 02:35 PM
Posts: 7,506 Az
Crizila
Az
Mine is an old Mr Gasket 11" wheel from 1979. I modified it by cutting the center out of it. Made an aluminum center so I could rotate the outer ring without having to loosen up the crank bolt. One of the best tool mods I ever did.
Fastest 300
[Re: DemonDust]
#1868807
07/12/15 02:59 PM
07/12/15 02:59 PM
Posts: 7,506 Az
Crizila
Az
The Mr Gasket one in the pics did come with an assortment of different size center hole adaptors, which I just adapted to my aluminum center section. Don't think I would go smaller than 12" dia. if I were to buy another one - if you want to read it in 1/2 degree increments.
Fastest 300
[Re: MR_P_BODY]
#1868862
07/12/15 04:39 PM
07/12/15 04:39 PM
Posts: 1,499 San Antonio,TX
440W8 Duster
San Antonio,TX
Jesse I have same one Mike has.
70 Duster W8 motor. 1.29 60ft 5.79 1/8 at 120 mph glide with 1.80 gear @3170 lbs.
[Re: MR_P_BODY]
#1868863
07/12/15 04:40 PM
07/12/15 04:40 PM
Posts: 5,155 CT
GTX MATT
CT
Me also, I believe it comes with 3 different buttons for mounting, and I had to modify one. It was close but not quite the Chrysler size as I recall.
[Re: DemonDust]
#1868886
07/12/15 05:21 PM
07/12/15 05:21 PM
Posts: 4,302 Nebraska
72Swinger
Nebraska
I printed one online and just glued it to an aluminum disc. $10 investment.
Mopar to the bone!!!
[Re: 72Swinger]
#1869210
07/13/15 03:15 AM
07/13/15 03:15 AM
Posts: 5,207 Menomonee Falls
DemonDust
Menomonee Falls
I printed one online and just glued it to an aluminum disc. $10 investment. That's a pretty small degree wheel. Can't be much bigger than 8"??? For $5 more you could have gotten a comp cams.
