Radiator Delema
#1868259
07/11/15 03:14 PM
07/11/15 03:14 PM
Posts: 1,131 Kent, WA
triple_green
Kent, WA
My car is stock/original down to everything but the wear items. The engine compartment looks factory stock, although it is not a show car.
I have had to redo my radiator about every 2-3 years. (Please forgive my lack of tech expertise). I have had to have it re-cored or tank repaired on this schedule. My understanding is that last time this was done everything was new, they just reused the rad supports and the top which has the part number, etc.
That cost $475 and only lasted 2+ years.
I really don't want to put in some huge aluminum radiator in an otherwise original engine compartment. Also I am not really in a position to spend $1000 on something either.
Any ideas? Any ideas why it leaks so soon after repair? I have used 3 different shops who otherwise have a good reputation.
Thanks! Mark
68 Charger, 383 HP console auto, spring green, stock restoration
Re: Radiator Delema
[Re: triple_green]
#1868275
07/11/15 04:06 PM
07/11/15 04:06 PM
Posts: 4,848 Memphis
HemiRick
Memphis
Assuming you have no electrical issues, and are running antifreeze at 50.50 ratio w water there's no reason this should be happening. Where is the radiator leaking? Many times they just need to be resoldered if the original job was subpar.
Take care, Rick 68 Coronet R/T 440 & 68 Charger 528 Hemi,and 5 Challengers! 6 cyl, 318, 360, 383, 451
Re: Radiator Delema
[Re: HemiRick]
#1868288
07/11/15 04:27 PM
07/11/15 04:27 PM
RapidRobert
I'm thinking poor fitment/workmanship in all three cases
Re: Radiator Delema
[Re: Pynzo]
#1868358
07/11/15 06:43 PM
07/11/15 06:43 PM
Posts: 14,889 up yours
Supercuda
About to go away
About to go away
up yours
Does the price include installation?
Re: Radiator Delema
[Re: Pynzo]
#1868394
07/11/15 08:02 PM
07/11/15 08:02 PM
Supercuda
About to go away
About to go away
up yours
Are you traveling to Chicago for a radiator repair? Or are you kidding? For the price, I assume a round trip ticket is included to install the thing.
Re: Radiator Delema
[Re: Supercuda]
#1868401
07/11/15 08:11 PM
07/11/15 08:11 PM
Posts: 1,386 Philadelphia PA
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
Are you traveling to Chicago for a radiator repair? Or are you kidding? For the price, I assume a round trip ticket is included to install the thing. Once again- are you kidding? Are you unable to turn your own wrench? Or do you need to have your Butler bring your Turbines To Speed? (Nerdy Batman reference).
Re: Radiator Delema
[Re: Pynzo]
#1868461
07/11/15 10:29 PM
07/11/15 10:29 PM
triple_green
Kent, WA
Thanks for all the good things to look into. I never thought about the electrical ground issues. The car shows no other signs of electrical problems.
Not sure where the traveling to Chicago theme came from. I usually pull the radiator myself and take to the shop. Although last time I did pay my longtime mechanic to do it just in case I was screwing up. He did use a high percentage antifreeze last time. Before I was following the 50/50 distilled water and prestone formula.
Glenray is great, but a little out of my price range right now.
Thanks for all the input!
Mark
Re: Radiator Delema
[Re: triple_green]
#1868476
07/11/15 10:48 PM
07/11/15 10:48 PM
Posts: 10,697 North Dakota
6PakBee
North Dakota
Have one of the local implement or equipment dealers do a chemical analysis on your anti-freeze. I'm going to guess you have a bad head gasket or a cracked head or something allowing combustion gas into the anti-freeze and the anti-freeze pH is very low. I had the same thing happen to me on a 360 and it turned out to be a crack behind one exhaust seat that had been installed.
Re: Radiator Delema
[Re: shorthorse]
#1868562
07/12/15 01:10 AM
07/12/15 01:10 AM
Posts: 27,451 So Cal
autoxcuda
So Cal
....snip.... However, electrolysis can occur without an external electrical source (called "chemical imbalance"). It is most common with aluminum radiators and iron blocks. "Dissimilar metals and alloys have different electrode potentials, and when two or more come into contact in an electrolyte (An electrolyte is a substance that ionizes when dissolved in suitable ionizing solvents such as water), one metal acts as anode and the other as cathode. The electro-potential difference between the dissimilar metals is the driving force for an accelerated attack on the anode member of the galvanic couple. The anode metal dissolves into the electrolyte, and deposit collects on the cathodic metal." There is a line of radiator caps that have an attached "magnesium sacrificial anode" and chemical electrolysis inhibitors on the market but I've never used them so I can't speak to their efficiency. I believe this is what happened to 70blackfish. His car would build voltage as it got up to operating temperature. He could turn the car off and it would still have too much voltage. Then he would disconnect the battery and STILL have voltage. He ran a sacrificial anode. Didn't do a darn thing for the two radiators that got holes ate through them. IIRC, he had voltages over 600 mV (.6 volts). He ran the Justice Brothers Radiator Cleaner and then the Justice Brothers Radiator Cooler that has chemical electrolysis inhibitors (metal deviators). Then we added an additional bottle of Justice Brothers Cooling System Protectant (CSP/1p) just for overkill and to be extra safe because he was having so much trouble. I believe he had something built up on the walls or stuck in the cooling system that was causing the electrolysis start up even though he was changing the fluid and changing it with his radiator swaps. And the chemical radiator cleaner helped with the additives.
