School me on 1970-71 Air Grabbers! #1868189
07/11/15 12:41 PM
07/11/15 12:41 PM
Halifax, N.S. Canada
Edison62 Offline OP
Edison62  Offline OP
I'm looking at putting a 1970 or 71 style Air Grabber assembly into a hood and wanted some input....are both years Vacumn activated? Can it be set up to operate via a cable? Any input appreciated.
Tnx,
Bryan.
Don't be stupid.... it's not smart!
1970 Super Bee. Big blk 4 speed car.
1973 Dodge Dart Sport 340 4 speed car.
1985 Dodge Ram D-100 /6 auto. Original paint
1990 Dodge Ram D-150 V-6 5 Speed. Original paint
1995 Chrysler LHS V-6 auto. Original paint
2014 Ram 1500 R/T 5.7 Hemi...!
Re: School me on 1970-71 Air Grabbers! [Re: Edison62] #1868212
07/11/15 01:35 PM
07/11/15 01:35 PM
IN
GTX4spd Offline
GTX4spd  Offline
IN
Yes, both years operate by combination of vacuum/electric circuitry. A cable system is possible, I did it on a different '70 GTX than the one I own now many years ago using the same cable that was used on the '69 setup, which is simply the cable for the passenger side fresh-air cabin vent. It was rather crude, today I would have the skills & tools to do a much better job than the "meatball surgery" I did then! An aftermarket choke cable would probably work better & would undoubtedly be cheaper these days. Finding all of the correct pieces to do the factory vacuum setup would likely be time consuming & costly, so unless you're wanting a factory look I'd go with the cable. twocents
"Gentlemen, we must all hang together, or surely, we shall all hang seperately."--Benjamin Franklin www.wwnboa.org if you're interested in '62-'74 B-Bodies
Re: School me on 1970-71 Air Grabbers! [Re: Edison62] #1868216
07/11/15 01:41 PM
07/11/15 01:41 PM
IN
GTX4spd Offline
GTX4spd  Offline
IN
Just noticed the sig pic in your post is a '70 Dodge. On those the fresh air system was called "Ramcharger" & in '70 was cable activated, same as '69. So while I suppose that you know your stuff & are actually talking about the Plymouth Air Grabber, I just wanted to be sure. In '71 Dodge used the vacuum system.
Re: School me on 1970-71 Air Grabbers! [Re: Edison62] #1868230
07/11/15 02:16 PM
07/11/15 02:16 PM
Edison62 Offline OP
Edison62  Offline OP
I'm actually looking to put one in my Dodge RAM hood.......
Bryan.
