JW Bell and starter question #1867828
07/10/15 06:07 PM
07/10/15 06:07 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
We recently changed over to a power glide using a JW bell and flywheel. We used all the correct parts and ended up having to space the starter out about a half inch. Is that the way it's supposed to be? Are there some starters that work better than others? We currently have a msd mini starter on it. It works but is hard to keep it tight. Thanks
Re: JW Bell and starter question [Re: bobs69] #1867835
07/10/15 06:33 PM
07/10/15 06:33 PM
WA
JD Dart Offline
JD Dart  Offline
WA
Mine only took 3 of their shims 1/2 seems like a lot. So are you using the JW wheel and their adaptor flange?
Re: JW Bell and starter question [Re: JD Dart] #1867839
07/10/15 06:48 PM
07/10/15 06:48 PM
ar.
bobs69 Offline OP
bobs69  Offline OP
ar.
Yes we used the wheel and crank adaptor
Re: JW Bell and starter question [Re: bobs69] #1867845
07/10/15 06:59 PM
07/10/15 06:59 PM
Australia
P
Project kickin A Offline
P
Australia
1/2" seems excessive, I had to space my starter out .120 and I thought that was a lot, I use a CVR starter
Re: JW Bell and starter question [Re: bobs69] #1867856
07/10/15 07:36 PM
07/10/15 07:36 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I ditched the supplied shims and made 2 1/4" thick spacers for a total of 1/2" to get it right. Used their crank adapter and flexplate. MP Denso starter and small block if it makes a difference.
Re: JW Bell and starter question [Re: CMcAllister] #1867858
07/10/15 07:40 PM
07/10/15 07:40 PM
Alexandria, LA
Blucuda413 Offline
Blucuda413  Offline
Alexandria, LA
Mopar mini starter and I only had to use 2 provided shims. I have to tighten mine after every outing..If it wasn't alum I would just loctite it.
Re: JW Bell and starter question [Re: bobs69] #1868029
07/11/15 12:40 AM
07/11/15 12:40 AM
Livermore, CA
Dduster Offline
Dduster  Offline
Livermore, CA
Yes,.. .approximately 1/2" thick spacer is what I needed to engage the PowerMaster starter motor to the JW flexplate along with the JW Ultrabell using a PG. You are using a 1/4" motor as well correct?
Re: JW Bell and starter question [Re: Dduster] #1868040
07/11/15 01:09 AM
07/11/15 01:09 AM
San Antonio,TX
440W8 Duster Offline
San Antonio,TX
I used 3 of there shims with a MP mini starter.
70 Duster W8 motor.
1.29 60ft 5.79 1/8 at 120 mph
glide with 1.80 gear
@3170 lbs.
Re: JW Bell and starter question [Re: bobs69] #1869258
07/13/15 09:43 AM
07/13/15 09:43 AM
South Florida
indcontrols Offline
indcontrols  Offline
South Florida
I have the same problem - but there is not space with the Megablock for either one of my mini starters.
I have a Reactor plate and JW bell w/glide- I used a factory starter over the weekend with about 1/2" worth of spacer to do some testing.... the starter only put up with 5 starts - then committed suicide...
I have a motor plate - are you guys using the little extension bushing that came with the JW bell for the nose of the starter ??
Re: JW Bell and starter question [Re: bobs69] #1869417
07/13/15 02:50 PM
07/13/15 02:50 PM
Fulton County, PA
CMcAllister Offline
Mr. Helpful
CMcAllister  Offline
Mr. Helpful
Fulton County, PA
I used the supplied bushing and 1/2" worth of spacers. 2 1/4" thick spacers, rather than a bunch of shims, on the MP starter. Worked fine for me. My mid-plate was relieved to allow the starter to bolt directly against the bell.
Re: JW Bell and starter question [Re: bobs69] #1870004
07/14/15 09:46 AM
07/14/15 09:46 AM
South Florida
indcontrols Offline
indcontrols  Offline
South Florida
Yup, I was looking at that as well... I think I'm going to give my mid plate a trim. I still can't decide if I want to grind on my Megablock to clear the high torque starters I have or just buy yet another one to fit.
Still sucks that you have to add that much spacer. I think once I figure out the exact thickness, I'm going to make one on the mill so I have a one-piece spacer.
Re: JW Bell and starter question [Re: bobs69] #1870761
07/15/15 03:46 AM
07/15/15 03:46 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
A lot of things will affect this..Just shim it the needed amount and run it! We have been from no shims to almost 3/4" out over the years. There is no consistency in ring gear placement or sometimes even crank flange placement with some stuff. It is what it is you wont hurt anything just shim it and forget it.
Re: JW Bell and starter question [Re: bobs69] #1870921
07/15/15 02:44 PM
07/15/15 02:44 PM
St. Charles, MO.
Slingshot383 Offline
St. Charles, MO.
Yep, shim as necessary. I put the factory stud in the upper hole to make installing the starter easier, have to use an index-able starter as the frame rail is right there (tube chassis - altered).
1994 Undercover Chassis 125" altered stack injected big block, soon blown and injected Member of The Torque and Recoil Club
