Drag radials, why are they,,,,,,,,, #1867902
07/10/15 09:18 PM
07/10/15 09:18 PM
gregsdart Offline OP
Harder on driveline parts? I am guessing there is not much sidewall give to cushion the driveline?
Re: Drag radials, why are they,,,,,,,,, [Re: gregsdart] #1867914
07/10/15 09:46 PM
07/10/15 09:46 PM
Plano, TX
StricNine Offline
StricNine  Offline
Plano, TX
Virtually no give compared to a slick due to the radial construction, they act like a street tire in that respect. The shock sent through the drive spikes higher (especially when they slip and grab, wheel hop, or whatever) vs a slick which will absorb some of that in the sidewall. They are also harder to recover once they start spinning (in my experience) vs a slick.
I've broken two axles and a spider gear on drag radials with "stock" power in my Challenger, after going to slicks I haven't broken anything (yet) despite better 60' times.
StricNine
79 Li'l Red Express, 15.04 @ 89.57
09 Challenger R/T, 11.95 @ 115.92
Re: Drag radials, why are they,,,,,,,,, [Re: gregsdart] #1868019
07/11/15 12:21 AM
07/11/15 12:21 AM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
The answer is simple.......you do NOT spin a drag radial. The tire is dead hooked or it is spinning, there is no in between. They also have a stiff sidewall, but it is not so much about the sidewall as the "hooked" part of it. Slicks "give" because they wrinkle up as well as black track when you hit them with real power. Radials are "hooked" and put ALL that power through the driveline. If there is a weak link, you will find it.
Walk through the pits at a race and look at the FAST radial cars. I am talking about the ones that run low 4s in the 1/8 and 60 foot in the 1.0s. These cars have massive power and are dead hooking the tire. They are built like Pro-Mods for a reason, they HAVE to be. They all have Pro-Mod style rears, with many even having floaters. Twisted and broken 40 spline axles are common, as well as broken chassis', ripped out 4-link brackets and bent housings. Many have now also gone to the Top Fuel type center in the rear wheels. These cars BREAK parts and bend up stuff, if not properly built.
Here is a graph of a 4.16 pass with a 1.06 short time. Notice what you DON'T see in the shaft speed.........tire slippage................ and the Gs are over 2.6 at the hit and climb to well over 3.4. That's HARD on parts
Monte
Re: Drag radials, why are they,,,,,,,,, [Re: gregsdart] #1868141
07/11/15 09:31 AM
07/11/15 09:31 AM
Chandler, AZ
Duner Offline
Duner  Offline
Chandler, AZ
The only breakage I've had with driveline hard parts was when I was using radials. Broke my 9.25 carrier in half somehow. LOL
Been just fine with regular slicks.
Re: Drag radials, why are they,,,,,,,,, [Re: gregsdart] #1868143
07/11/15 09:36 AM
07/11/15 09:36 AM
I am amazed that the radial tires hold that well. I am guessing these cars are on the edge of losing traction, most all of the run?
Monte, has there been any improvement or lessons learned concerning the "radial rock" that some radial drag tires are/were plagued with?
Re: Drag radials, why are they,,,,,,,,, [Re: gregsdart] #1868213
07/11/15 01:36 PM
07/11/15 01:36 PM
North Alabama
Monte_Smith Offline
Monte_Smith  Offline
North Alabama
It's ALL about power management, but once you get it stuck and moving, the radials will ALWAYS be faster than slicks.
"Radial Rock"...........never heard that and have no idea what you are referring to
Re: Drag radials, why are they,,,,,,,,, [Re: gregsdart] #1868449
07/11/15 10:03 PM
07/11/15 10:03 PM
I had radial Slicks on from Mickey Thompson 10 years ago.They would start to twist the car from side to side so bad I had to lift on have the runs I made. Superstock racers have had the same trouble running the radial Slicks.
Re: Drag radials, why are they,,,,,,,,, [Re: gregsdart] #1868488
07/11/15 11:07 PM
07/11/15 11:07 PM
weymouth,mass.
meepmeep70 Offline
meepmeep70  Offline
weymouth,mass.
I miss the popcorn eating smiley
Re: Drag radials, why are they,,,,,,,,, [Re: meepmeep70] #1868591
07/12/15 01:58 AM
07/12/15 01:58 AM
Az
Crizila Offline
Crizila  Offline
Az
Personally, I don't likem. Couldn't get a feel for them and what they were doing. Spent half my time at the track trying to dial them in. Minor temp track changes and you will be forever focking around with tire pressures and suspension changes. They wouldn't let me change my dial at half track, so I got rid of them. laugh
Fastest 300
Re: Drag radials, why are they,,,,,,,,, [Re: meepmeep70] #1868618
07/12/15 02:52 AM
07/12/15 02:52 AM
CT
GTX MATT Offline
GTX MATT  Offline
CT
popcorn
Re: Drag radials, why are they,,,,,,,,, [Re: gregsdart] #1868810
07/12/15 03:05 PM
07/12/15 03:05 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
I think you guys are talking about 2 different type of tires. Monte was talking about a drag radial tire, and your talking about a drag radial slick, which have been known to oscillate the car from side to side.
Re: Drag radials, why are they,,,,,,,,, [Re: gregsdart] #1868856
07/12/15 04:24 PM
07/12/15 04:24 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
The tires have changes so much in 10 years.
