Re: Converting dash lights to superbright LEDs - Questions..
[Re: stumpy]
#1875244
07/21/15 07:27 PM
07/21/15 07:27 PM
Posts: 1,386 Philadelphia PA
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
Yes. The H.L. Switch actually controls 2 seperate circuits with 2 different power feeds. Black with white tracer wire (from main harness power in splice) switches to green power wire to Floor H.L. Dimmer switch. Power from dome lamp circuit runs to H.L. Switch (pink wire pigtailed to grey clock wire at back of switch) and powers the Parking Lamps. When you turn on Parking Lamps power flows through Switch to yellow wire to Dimmer Switch. Pic shows the Dome/ Cigar Lighter circuit removed from a '70 Coronet Dash Harness. Top Right you can see the fuse tap with red and pink wires. That's where power enters this circuit.
[Re: stumpy]
#1875599
07/22/15 08:46 AM
07/22/15 08:46 AM
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
Well if you had the '70 Coronet FSM then you could have pointed out that I was wrong. Power to the dimmer switch does come through the H.L. Switch, but from the Stop and Tail Lamps fuse, not the Dome Lamp, as I had previously posted, and through a black wire pigtailed from the back of the H.L. Switch, other end pigtailed to a yellow w/ black tracer wire at back of Dimmer Switch. What's confusing about the FSM schematic is the multiple use of Pink Wires. Three different circuits use Pink as power wires, Parking Lamps- dimmable circuit, Windshield Wiper, and Brake- Dome Lamp( from the Hazard Flasher which also runs power to the Flasher Switch, opposite side of connector). And the Brake Lamps are on the Hazard Flasher fuse, not the Stop and Tail Lamps fuse. The '70 Coronet FSM is not available for free download from MyMopar.com, and the schematic they have available pales in comparison to what's printed in the FSM.
[Re: Pynzo]
#1875926
07/22/15 05:51 PM
07/22/15 05:51 PM
Posts: 33,005 Grand Prairie,Texas
stumpy
Grand Prairie,Texas
Doesn't the headlight switch feed the dimmer? Otherwise the dash lights and parking lights would be on all the time. I believe I said you were incorrect and didn't need a manual to figure it out.
[Re: stumpy]
#1876025
07/22/15 07:44 PM
07/22/15 07:44 PM
Pynzo
Drugs are bad
Drugs are bad
Philadelphia PA
That read like a question, so I answered it. Didn't recognize it as a cryptic remark on my response. My bad. And I am correct- pink wire powers the parking lamps and dimmer switch.
[Re: OLD318]
#1876709
07/23/15 06:30 PM
07/23/15 06:30 PM
OLD318
in your diagram - E1-18T Instrument Lamp (FEED) feeds the instrument panel fuse in the fuse block. The E2-18O (fused output)goes to the instrument panel lights. Both 18T (top of the fuse) reads 0 volts as does 18O) bottom of the fuse... when using the voltmeter...
My thinking is my dimmer switch is bad... as all other lights, Dome, door jam switches, turn signals and indicators on the dash, H/L headlamps. bright light indicator and map light all work...
From the diagram this implies that the H/L feed to the dimmer switch L7A-18BK is hot - otherwise no dome light etc...
What do you guys think?
[Re: OLD318]
#1876893
07/23/15 10:12 PM
07/23/15 10:12 PM
Posts: 1,379 Tennessee
WyleECoyote
Tennessee
That's my problem - no dash lights now! When I work the dimmer switch I get nothing.
I checked the fuse block - no voltage at either the top of the fuse or the bottom of the fuse - I took the fuse out and it's perfectly intact not blown.
I guess I need a new dimmer switch (sucks!) anyone else ever have this problem? I installed the 5-LED Lights from O'Reilly's in the dash of my 84 D350. I installed four of the nine and stopped to check them out. They looked great. I continued on and installed the rest - and then they didn't work. I chased the problem for DAYS. My finding: They were polarity sensitive!!! I used my Power Probe to find the + and - of each bulb, then traced the circuitry of the dash insert for the + and - and installed the bulbs accordingly and then, they worked!! Good Luck!
Wile E. Coyote Super Genius, Lover of FCA US LLC Products ************* 68 Road Runner (440 4-spd), 71 Superbee (383 slap), 71 Charger 500 (383 4-spd wA/C 1of 182), 72 Imperial, 74 Charger SE (440 sunroof), 84 D350 Crew-cab Dually (440), 75 D300 Dually Tandem (318 4-speed)
