Page 4 of 5 1 2 3 4 5
Re: 66 Satellite barn find/ build project. [Re: cirrusaero] #186779
12/11/09 11:07 PM
12/11/09 11:07 PM
Nice car.
Re: 66 Satellite barn find/ build project. [Re: ] #186780
12/12/09 07:42 PM
12/12/09 07:42 PM
Mira Loma, CA
69B3GT Offline
69B3GT  Offline
Mira Loma, CA
That has got to be the coolest oldschool looking car ive seen. Very Nice
Any track time yet?
Re: 66 Satellite barn find/ build project. [Re: 69B3GT] #186781
12/13/09 04:47 PM
12/13/09 04:47 PM
ct
jkgtx Offline
jkgtx  Offline
ct
reminds me of my car when I started on it 30
years ago yours was in better shape:)
[b] [color:"red"] 67 GTX 440 twin turbo efi 10.72 128 3900lb 3.55
Re: 66 Satellite barn find/ build project. [Re: 69B3GT] #186782
12/26/09 09:24 PM
12/26/09 09:24 PM
Chandler, AZ
cirrusaero Offline OP
Chandler, AZ
Any track time yet?
Yep, just took it to the track 2 weeks ago. Keep in mind that I don't have much drag racing under my belt but I managed to make it down the track without hurting myself or anyone else. I made a total of 6 passes just to make sure the car was A-okay. ( it did break a little )
First pass got a decent burn out but since it was the first run I just wanted to take it easy. R/T .156, 1/8th 7.63, 1/4 14.47, 89mph.
2nd run: R/T .152 1/8th 7.45, 1/4 13.53, 87.67mph (Still short shifting into 3rd and cruising to the line)
3rd got a bad burnout tires spinning all through 1st gear: R/T .243, 1/8th 7.78, 1/4 12.28, 108mph
4th run: good burnout R/T .124 1/8th 6.97,1/4 11.96 114 mph (still short shifting into 3rd gear)
5th run: good burnout R/T .198 1/8th 6.73, 1/4 11.61, 107 mph.
The last 2 runs the MSD box seemed to be cutting out over 4k RPM. The battery was draining and I didn't bring enough tools to check it out or fix it. Figured I'd pack it up and crawl home. I drove the car there and my headlights were dimming to almost nothing so I just drove with the parking lights on.
So I have a little bit of work cut out for me. Tech inspector asked me to put the battery in a legal box since it's in the trunk, need metal valve stems on the wheels, and few other misc. things. Overall it was a blast and can't wait to take it back next month.
68 Charger 605 Hemi, Keisler 5spd, Pro-touring
66 Coronet 2dr post
66 Satellite
Re: 66 Satellite barn find/ build project. [Re: cirrusaero] #186783
12/27/09 02:01 AM
12/27/09 02:01 AM
Spokane Washington
ScottSmith_Harms Offline
Mr Wizzard
Mr Wizzard
Spokane Washington
After you get your electrical system under conrol (I'd start with the ballest resistor, alternator, then the voltage regulator with a charging problem) check your fuel pump and fuel filter, it could have been from lack of spark with a weak battery but that sounds like it could also be starving of fuel at higher rpms under load.
Re: 66 Satellite barn find/ build project. [Re: ScottSmith_Harms] #186784
12/27/09 08:04 AM
12/27/09 08:04 AM
Jersey shore
Gary67 Offline
super street
Gary67  Offline
super street
Jersey shore
If your charging problem started after the relocation you also could check voltage drop over the alt/bat run. I know some people just use a #10 or #12 wire for that. IMO at least#8 should be run back to the battery from the alt even better #6. Can't have enough grounds either...just thinking out loud, I'm sure you'll nail it down...
Re: 66 Satellite barn find/ build project. [Re: Gary67] #186785
12/27/09 03:52 PM
12/27/09 03:52 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
11.61 already. You gotta be happy with that for a baseline.
Sheldon
Re: 66 Satellite barn find/ build project. [Re: RUNCHARGER] #186786
01/20/10 06:15 PM
01/20/10 06:15 PM
Denver, Colorado
sparkswillfly Offline
Denver, Colorado
Wow, cool car!
What size rim/backspace are you running on the rear?
Again, awesome car!
Re: 66 Satellite barn find/ build project. [Re: sparkswillfly] #186787
01/20/10 11:26 PM
01/20/10 11:26 PM
Chandler, AZ
Chandler, AZ
rear rims are a 15 x10. backspacing is 5.75. There is not much room on either side of the stock wheel wells but it does NOT rub. The outer lip was tweaked in a little and the inner/trunk area was sledge hammered in But like I said that was they way they did it back in the day.
FYI This car will be driven up to Mopars at the Strip.
66 Coronet 2dr post
66 Satellite
Re: 66 Satellite barn find/ build project. [Re: cirrusaero] #186788
01/22/10 11:10 AM
01/22/10 11:10 AM
Denver, Colorado
Denver, Colorado
Cool!
Thanks for the info.
Re: 66 Satellite barn find/ build project. [Re: sparkswillfly] #186789
01/22/10 07:59 PM
01/22/10 07:59 PM
N.Wilkesboro,NC
DusterKrazy Offline
DusterKrazy  Offline
N.Wilkesboro,NC
I really like this! What did you use for the subframe connectors?
Re: 66 Satellite barn find/ build project. [Re: DusterKrazy] #186790
01/25/10 12:14 AM
01/25/10 12:14 AM
Chandler, AZ
Chandler, AZ
Greg Fernald @ SS and AFX ( www.ssandafx.com ) did the subframe connectors for me since I can't weld to save my life.
66 Coronet 2dr post
66 Satellite
Re: 66 Satellite barn find/ build project. [Re: cirrusaero] #186791
01/27/10 08:28 PM
01/27/10 08:28 PM
ne
broncobra Offline
broncobra  Offline
ne
Wicked cool car!
Re: 66 Satellite barn find/ build project. [Re: broncobra] #186792
12/18/12 05:33 PM
12/18/12 05:33 PM
Chandler, AZ
Chandler, AZ
Question: What is a good rust preventative for the bare metal behind the door panels, under dash inside trunk area ETC? I recently moved from Phoenix to South Florida and I don't want to see this original bare metal get any surface rust. The car is not in Florida yet and I'd like to prevent this before it gets out here.
Someone suggested Pledge since it is silicon based wax but it'll be a [Edited by Moparts - Family Friendly Site - Keep it clean] to get off should I ever want to paint the car.
66 Coronet 2dr post
66 Satellite
Re: 66 Satellite barn find/ build project. [Re: cirrusaero] #186793
01/29/15 02:44 AM
01/29/15 02:44 AM
Wisconsin
N
NI4NI Offline
NI4NI  Offline
N
Wisconsin
Hello Kevin,
I came across your awesome machine and am wondering if it's still turning heads out in the Chandler area. I have an uncle who lives out there and there's little doubt that he's seen your nice wheels out on the town.
Keep her looking nice!
Brian
1974 Plymouth Satellite Sebring Plus, 4bt turbo intercooled Cummins, SlapStik A727, 224 rear end gears http://www.4btswaps.com/forum/showthread.php?t=9632
Re: 66 Satellite barn find/ build project. [Re: NI4NI] #186794
01/29/15 02:03 PM
01/29/15 02:03 PM
Back in NJ....
E
EWJ Offline
EWJ  Offline
E
Back in NJ....
The car is currently here in NJ with Kevin's brother. Very cool car.....
Ed
EastCoast Land Yacht Assoc.
1967 Newport Conv: 440/4 speed
1969 GTX: 440/4 speed, TX9/TX9, A34, N96
1970 Super Bee: 383/4 speed, B5/B7
1970 Coronet RT: 440/4 speed, A34, N96
1970 Coronet RT: 440/auto, A36, N96
1970 Road Runner convertible: 383/4 speed TX9/D6XW
1970 GTX: 440+6/727, A32, N96
2001 Dodge 2500 HO CTD, 6 speed, 4x4 quad cab long bed
"The early bird may get the worm, but the 2nd mouse gets the cheese".
Re: 66 Satellite barn find/ build project. [Re: EWJ] #186795
01/31/15 01:48 AM
01/31/15 01:48 AM
Wisconsin
N
NI4NI Offline
NI4NI  Offline
N
Wisconsin
Hi Ed, thanks for the quick follow-up on my inquiry. Yes, she's looking awesome and thankfully in good hands.
Hang in there,
Brian
Re: 66 Satellite barn find/ build project. [Re: cirrusaero] #186796
01/31/15 02:27 AM
01/31/15 02:27 AM
Spokane Washington
Mr Wizzard
Mr Wizzard
Spokane Washington
There are lots of choices in that area, most are topicals like Pledge, WD-40, Wax, or my choice, RPM (from ECS) etc. If you paint it down the road these areas could left bare metal just as they are now, or you should be able to prep them properly with a light sand/scuff and a good wax & grease remover, no big deal.
Re: 66 Satellite barn find/ build project. [Re: ScottSmith_Harms] #186797
01/31/15 02:25 PM
01/31/15 02:25 PM
APACHE JUNCTION AZ
Joesixpack Offline
Joesixpack  Offline
APACHE JUNCTION AZ
lol nice ride just caught the story, whatever happened to the metal scoop? have a 66 steel hood with a cutout center allready, could use a scoop like that...
Re: 66 Satellite barn find/ build project. [Re: Joesixpack] #1985773
01/07/16 07:21 PM
01/07/16 07:21 PM
Chandler, AZ
Chandler, AZ
Well the car never made it out to Florida. I moved to a peninsula off the coast of Stuart Florida and we barely made it two years there before moving back to the Phoenix, AZ area. Car is back here enjoying the dry desert air. But sadly I think the time has come to sell it. When I first bought the car I had 3 kids that I was a Foster Parent to but I know have 5 kids, all adopted and part of the family for good and I just don't have the time to drive it. I hope someone can really appreciate this car for what it is.
See if i can figure out how to add a youtube video of it driving.
66 Coronet 2dr post
66 Satellite
