Clutch pedal vibrates #1866910
07/08/15 09:40 PM
07/08/15 09:40 PM
Maryland
glenngomango Offline OP
Maryland
The clutch petal on my 70 cuda is tight and vibrates when when the car is traveling in 1-2 gear. Does this need adjustment before I drive it 300 miles to Carlisle??
Re: Clutch pedal vibrates [Re: glenngomango] #1867084
07/09/15 05:40 AM
07/09/15 05:40 AM
Rancho Cucamonga, CA
D_C Offline
D_C  Offline
Yes.
Adjustment should be easy unless you have broken, missing parts, or worn out clutch linkage.
Of course, it could be an actual clutch problem.
Definitely would investigate before driving 300 miles and needing a tow.
Re: Clutch pedal vibrates [Re: glenngomango] #1869556
07/13/15 06:14 PM
07/13/15 06:14 PM
Niwot, CO Formerly denn...
dynorad Offline
dynorad  Offline
It sounds like you are riding the throw out bearing.
