Re: Opinions on 727 vs 'glide vs ????
[Re: 80arrow]
#1866842
07/08/15 08:10 PM
07/08/15 08:10 PM
Posts: 10,010 Frostbitefalls MN (Rocky&Bullw...
gregsdart
Clint, you must have something more than stock springs and shocks, I assume? What all do you have? The glide would definitely help you get the car down the track, and you might be approaching the limits of the stock internals of a 727.
[Re: 80arrow]
#1866853
07/08/15 08:35 PM
07/08/15 08:35 PM
Posts: 8,094 Sunnyvale, CA
Jeepmon
Sunnyvale, CA
I've recently asked this same question about my 1000hp ladder bar, big tire car after breaking a slightly built-up 727 for the 2nd time... Pretty much the consensus was a Pro-flight (built 727) will handle the torque of the motor, but will require frequent maintenance... The PG trans will hold the power better and longer with less maintenance..
If you currently have a TF trans, the cost of swapping out a Pro-Flight is real close to the cost to convert over to a PG.. The PF runs $5500-ish.. which is about the same cost to buy a built PG with the adapter kit, crossmember, shifter and driveshaft..
I've heard the PF will be a little faster in the 1/4 mile, but the PG weighs less and replacement parts are cheaper and easier to find..
Good luck with your trans and be sure to post on here your progress
[Re: 80arrow]
#1866865
07/08/15 08:51 PM
07/08/15 08:51 PM
Posts: 19,372 Las Vegas
Al_Alguire
Las Vegas
A ProFlite WONT handle a ton of TQ without at the very least FREQUENT maintenance and occasional failures. I am not speculating I have seen and experienced it. In cars with a LOT of torque something like a Rossler TH210 or similar is the way to go. Wander around Top Sportsman and Pro Mod pits and see what they use for a true automatic. You will not find a Proflite among them. Proflites are great pieces SS and Comp cars that make good power with smaller cubes and not tons of torque. If you have a high winding 400ish" sb making 1100hp and not much torque then they are the quick way down the track. But they do not live long happy lives even there. I know I know the Hemi guys run them, Well let me tell ya they aint making killer TQ but make good power at high RPM's.
A glide can be built to handle whatever power you are making. The old wives tale about they don't work in heavy cars is just that, bunk! Just build it for it's intended purpose. Something like a Rossler XHD will live a long happy life behind a powerplant like yours as well. I just sold mine for a sons(actually traded it off)but don't be shy. Transmissions like that do not come cheap for sure.
In your case a true all the bells and whistle Proflite MAY work. I don't know what kind of torque you are making with that set up. Being a SB it may be ok. FWIW an all the bells and whistles ProFlite is NOT $5500 either..Both the Proflite and Rossler offer a variety of first gear ratios as well. So does a glide. But for a blown combo I cannot imagine you want a ton of first gear..
IMO if you are like most of us and have plans of some day going to more power just go right to the best piece available. Money wise a Rossler is on par with a Proflite and if it were my money would be the direction I would go.
[Re: SCDaytona]
#1866976
07/08/15 11:51 PM
07/08/15 11:51 PM
Posts: 13,200 aZLiViN
J_BODY
aZLiViN
It's funny no one asked what is his application. Is the car a bracket car? I'll go out on a limb and say a procharged drag radial equipped small block with the listed HP definitely IS NOT a bracket car. I'd also believe that this combo set on kill will run quicker with the 3spd.
[Re: 80arrow]
#1866983
07/09/15 12:06 AM
07/09/15 12:06 AM
Al_Alguire
Las Vegas
99 Hemis do not make killer torque. I ran one for a few here years, in a much heavier car than a comp car. Watched a buddy in TS wrestle the PF issue and it never stayed together and they worked directly with Dave. I have a buddy I am helping as well with a PF behind a 99, also in a 2200lb ex pro stock car, similar to what a B/AA car would be. I agree in a heads up deal the three speed should be the faster way down the track. But SS/AM and a B/AA car are a different animal than SB procharged heads up type car. Don Call Adam tell him I told you to call and inquire about a ProFlite. I think you will find by the time you are done you will be well north of that number. I have his cell if you like Just sayin Don't get me wrong a PF is a very good piece and in most of the fastest comp and SS cars in the country. Most of which are high winding relatively low torque high RPM deals. We use one in the heads up car. A smallish motor that is shifted north of 9500rpm. Works well in this environment for sure. If that was what I was running believe me I would have one..I will also admit that since we switched from a Th400 based tranny we have not picked up much of anything. But we just made the switch 9 passes ago.
[Re: 80arrow]
#1867000
07/09/15 12:32 AM
07/09/15 12:32 AM
Al_Alguire
Las Vegas
That is a good question and something I did not know...Maybe I am the village idiot here afterall
[Re: 80arrow]
#1867067
07/09/15 03:02 AM
07/09/15 03:02 AM
Posts: 6,890 North Alabama
Monte_Smith
North Alabama
Lets see here.......Procharger, check............radials, check..........1100hp, check........3500lbs, check.......Pro-Flite, HELL NO...........LOL!!!
Monte
[Re: 80arrow]
#1867070
07/09/15 03:12 AM
07/09/15 03:12 AM
J_BODY
aZLiViN
well that was about the shortest post I've ever seen from you Monte.... What thou say? fwiw I have no dog in this fight, but it's a very interesting subject. I'll be sticking with my torqueflight. I'm not making oodles of power, it's bought and paid for along with the converters, and it's also very easy for me to pull the W8 mill and simply install the iron head piece in it's place..... at least that's my story for now. Don't worry Don.... I hear the PG is even easier to work on. We'll tear right in to it if need be. I got help just a phone call away!
[Re: J_BODY]
#1867072
07/09/15 03:19 AM
07/09/15 03:19 AM
Monte_Smith
North Alabama
well that was about the shortest post I've ever seen from you Monte.... What thou say? fwiw I have no dog in this fight, but it's a very interesting subject. I'll be sticking with my torqueflight. I'm not making oodles of power, it's bought and paid for along with the converters, and it's also very easy for me to pull the W8 mill and simply install the iron head piece in it's place..... at least that's my story for now. Don't worry Don.... I hear the PG is even easier to work on. We'll tear right in to it if need be. I got help just a phone call away! If you notice, I said PRO-FLITE, which some were suggesting he run. I don't care who runs them in what, it won't last til the water gets hot on a 1100hp car with drag radials.........Now as far as a 727, could he make it live behind his combo, probably. But gear ratio selection will be a problem. You could make it a second gear leaver.....but for the money invested, just do the glide and be done with it
