Re: Distributor slot chart for SB old style
[Re: D_C]
#1866153
07/07/15 09:58 PM
07/07/15 09:58 PM
Posts: 1,373 Rancho Cucamonga, CA
D_C
Here is a Post with a Chart on the First Reply: There's a "backyard chart" of slot length to degrees advance............ Dimensions for Mopar distributor slots, in DISTRIBUTOR degrees Modifying advance slots degrees / slot size 6.............. .340 7................355 8................375 9................390 10...............405 11.5 ...........420 12...............435 13...............445 14...............460 15...............475 16...............490 17...............505 18...............520 http://www.forabodiesonly.com/mopar/archive/index.php/t-182247.html
[Re: D_C]
#1866337
07/08/15 02:15 AM
07/08/15 02:15 AM
RapidRobert
I'd (1) set initial with "vac gauge method" (2) with that number in hand shorten the slots (per the chart) to get 35 total (initial+slots with can capped) (3) mix/match springs so you are just under the pinging point at WOT up thru the gears on your hottest/driest day (4) then plug in/adj the can (CCW with a 3/32" allen wrench makes it come in slower) and you want to be just under the pinging point in everyday driving under varying vac levels/RPM levels on your hottest/driest day. Mr gasket has a light spring kit 925B as does MP (the 925B might b e the mr gasket number. I would toss the heavy spring with the long loop on one end. spring rate is linear no matter which ones you use (ex for the long loop one that I would toss). here's a chart for #3 just for reference (if I can post it) but go by pinging & there is silent pinging so have a slight cushion
