Cool deal on Indy's website
#1864352
07/05/15 04:13 PM
07/05/15 04:13 PM
Posts: 4,243 Charlotte, North Carolina
sgcuda
So I wanted to look up a water manifold remembering Indy used to make one for the big blocks and I came across this in the clearance section: http://www.indyheads.com/overstock.htmlStage VI heads and intake for $795. Looks like a deal of a lifetime to me. Thought I would pass it along for anyone wanting to upgrade to aluminum heads. Pic shows bare heads, but it seems like a great starting point.
[image][/image]
Re: Cool deal on Indy's website
[Re: GTS340]
#1864492
07/05/15 07:55 PM
07/05/15 07:55 PM
Posts: 2,411 Weatherford, Texas
RapidusMaximus
Weatherford, Texas
So it may seem like a deal. Better plan on spending another $1500+ for 1. Porting that is an absolute must (unless you want peformance lower than factory iron heads offer) 2. Valves and valve job 3. Rocker stands 4. Miscellaneous machine work to correct various issues 5. Offset intake rockers We have built a set of those, in the end you will wish you would have went a different route! But the reputation Indy has combined with the reputation the MP Stage 6 has I think most people would know to pass Not sure I agree with your assessment...: 1. my bone stock Stage 6's were way lighter than my 906's and they flowed better out of the box 2. yes, if these heads re bare they will need valves and a valve job, 3. Rocker stands? Mine have "stock" rocker stands and accepted stock rocker gear...still do. 4. maybe I was lucky but mine needed no "various" issues corrected...yes...I've read all over the internet and on this site how bad some people and found them to be but mine may be the exception??? 5. Offset rockers not required for Stage 6's Bottom line I would think it doesn't sound like that bad of a deal to me...and as I side note I made 782 hp with mine on a 499 low deck stroker, ran them for over 10 years and they are now sitting on my shelf waiting on the next project. my 2 cents. Yes, they have been ported...twice as a matter of fact, once by Muscle Motors and the second time by a small independent shop.
1968 Plymouth GTX 1974 Dodge P/U Long Bed Stepside 318 2019 Ram 2500 6.4, auto, 4WD
[Re: wyldebill]
#1864563
07/05/15 09:08 PM
07/05/15 09:08 PM
RapidusMaximus
Weatherford, Texas
What do they flow,after the port work? Any idea what the flow potential is? Don't know what they flowed when I originally bought them from muscle motors, but at the time I was moving from ported 906's to the stage 6's (mid 90's) and they picked me up from 5.50's to 5.30's in a stock stroke 440 in a hard tail dragster. Port job II was done by a small shop in Dallas that specialized in small block chevy's, he gave me a piece of notebook paper back then that had flow numbers on it...he was claiming on the paper that he flowed them to 341...is that possible? I won't argue yea or nay, all I can say is that they went on my 499 low deck in my hard tail dragster and ran 4.80's at 140 for years, now they are sitting on my shelf, still don't require off set rockers and the rocker stands are intact...quit bracket racing so they are waiting for a good street build. Dwayne Porter is the most experienced person I have heard of on these heads and I would love to send mine to him for evaluation but just haven't done it yet.
[Re: sgcuda]
#1864849
07/06/15 01:28 AM
07/06/15 01:28 AM
Posts: 2,540 Milwaukee WI
TRENDZ
Milwaukee WI
Most likely these are low qc cast offs from chapman. These castings have the greatest potential of all the stage 6 heads, if you are willing to do the work.
[Re: RapidusMaximus]
#1864945
07/06/15 10:47 AM
07/06/15 10:47 AM
Posts: 403 Romulus, MI
GTS340
Romulus, MI
So it may seem like a deal. Better plan on spending another $1500+ for 1. Porting that is an absolute must (unless you want peformance lower than factory iron heads offer) 2. Valves and valve job 3. Rocker stands 4. Miscellaneous machine work to correct various issues 5. Offset intake rockers We have built a set of those, in the end you will wish you would have went a different route! But the reputation Indy has combined with the reputation the MP Stage 6 has I think most people would know to pass Not sure I agree with your assessment...: 1. my bone stock Stage 6's were way lighter than my 906's and they flowed better out of the box 2. yes, if these heads re bare they will need valves and a valve job, 3. Rocker stands? Mine have "stock" rocker stands and accepted stock rocker gear...still do. 4. maybe I was lucky but mine needed no "various" issues corrected...yes...I've read all over the internet and on this site how bad some people and found them to be but mine may be the exception??? 5. Offset rockers not required for Stage 6's Bottom line I would think it doesn't sound like that bad of a deal to me...and as I side note I made 782 hp with mine on a 499 low deck stroker, ran them for over 10 years and they are now sitting on my shelf waiting on the next project. my 2 cents. Yes, they have been ported...twice as a matter of fact, once by Muscle Motors and the second time by a small independent shop. MW gasket, milled rocker stands, Tons of material to be removed, just look in the bowls.
[Re: sgcuda]
#1864951
07/06/15 10:56 AM
07/06/15 10:56 AM
TRENDZ
Milwaukee WI
I guess they're not chapmans. The spring surface is for a standard length valve.
[Re: PorkyPig]
#1865430
07/06/15 09:46 PM
07/06/15 09:46 PM
RapidusMaximus
Weatherford, Texas
I second the above response...those don't look anything like my stage 6s or any that I have ever seen????
[Re: sgcuda]
#1865750
07/07/15 10:42 AM
07/07/15 10:42 AM
Posts: 13,357 Marion, South Carolina [><]
an8sec70cuda
There's a reason they're so cheap.
[Re: an8sec70cuda]
#1865844
07/07/15 01:27 PM
07/07/15 01:27 PM
GTS340
Romulus, MI
There's a reason they're so cheap. Exactly!!! But building them into something decent will not be cheap!
